Results 1 to 13 of 13
    mlcktmguy
    Jan 2017
    Fat Bike Frame Repair?
    I've only been into mtn biking for a couple years. I bought a used Farley 5 about a year ago and it's been very good.
    I was cleaning it after the Sunday ride and noticed a crack in the frame.
    It's not a carbon frame.
    Can these be repaired?
    2018 Trek Stache 7
    2016 Trek Superfly 6
    2016 Trek Farley Build
    Life's a ride, enjoy it! Moderator
    Reputation: life behind bars's Avatar
    May 2014
    Not repairable.
    Wanted, SRAM GX 2x11 rear derailleur
    It ain't supposed to be easy.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    There are many carbon-fiber repair outfits that can repair that these days.
    May 2014
    It's an aluminum frame.
    Reputation: dbhammercycle's Avatar
    I would look for a frame to swap parts over...
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Quote Originally Posted by life behind bars View Post
    Damn! I read the "its not a carbon frame" as "it's a carbon frame", Doh!
    Oct 2016
    Warranty
    mlcktmguy
    Jan 2017
    No warranty, I bought the bike used.
    A friend of mine has some clients that are certified welders on all kinds of metals including aluminum. They want to take a look but feel pretty confident they can repair the crack to its original strength or better.
    I've had others tell me that once its cracked you can't trust it even if it's been repaired. Seems like the repair is worth a try, especially in the hands of capable welders used to working with this kind of material.
    Any thoughts?
    2018 Trek Stache 7
    Oct 2016
    It won't hold up long repaired. I would still try to get it warrantied, maybe trek will hook you up with a crash replacement for cheap.
    May 2014
    Quote Originally Posted by mlcktmguy View Post
    Any thoughts?
    As a long time welder and someone that builds the occasional frame, even if welded to repair it would still need to be heat treated to maintain the original level of tensile strength. Try it but never trust it.
    Dec 2017
    A cracked aluminum bicycle frame is not repairable.
    Aug 2005
    Have you called Trek yet? Trek should replace the frame regardless of how many owners it had. A friend of mine got a new frame from Trek after he noticed a crack in an old Gary Fisher frame he bought used.
    Vermonter - bikes, beers and skis.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Quote Originally Posted by VTSession View Post
    ... Trek should replace the frame regardless of how many owners it had...
    They'd be on the hook for a heck of a lot of frames if that were the case.
    Do the math.
  1. fat bike repair stand... options???
    By rpedro in forum Tooltime
    Last Post: 11-24-2015, 02:10 PM
  2. Replies: 16
    Last Post: 08-26-2014, 09:01 AM
  3. Getting a bike frame painted by auto body repair?
    By roc865 in forum Bike and Frame discussion
    Last Post: 02-08-2014, 01:05 AM
  4. To Frame Repair or Not Frame Repair
    By Single Trak Mind in forum General Discussion
    Last Post: 12-18-2012, 04:48 PM
  5. Not a frame but a bike repair stand.
    By Jeff Stevens in forum Frame Building
    Last Post: 04-05-2011, 04:44 AM
