Do you ride your Steel frame through a creek?- Mtbr.com
Results 1 to 11 of 11
    Reputation: joe_bloe's Avatar
    I'm in the process of building up my first steel bike, an '08 Kona Unit. I got thinking about my weekly Wendesday Night ride, in which we cross a couple of creeks, some of which can be quite deep depending on the weather. Should I avoid dunking my bottom bracket under water on a steel bike?
    I ride steel and have never given it a thought about riding it through water...Now I am a bit anal about taking my bike apart on a regular basis and make sure all is good and everything is good to go
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    you might want to get a can of JP Weigle Frame Saver and treat the inside of your frame with it
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    Great tip, thanks.
    Quote Originally Posted by Zoke2 View Post
    I was wondering if such a thing existed. Thanks, +Rep!
    Reputation: laffeaux's Avatar
    You should actually avoid dunking your BB under water on any bike - regardless of the frame's material, bottom brackets (particularly their bearings) aren't fan's of water.
    When I build up steel frames I generally coat the inside of the BB shell with a light coating of waterproof grease (Phil Wood or Park Tool grease) so that if water does get into the frame that it's not pooling against bare metal. Also, if you have a steel fork, a light coat of grease on the steerer tube will keep it from rusting too.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    El Gato Malo
    If the frame does get a good dunking, take the seatpost out and turn the frame over to drain. I haven't used the Weigle product but have dripped in some motor oil for interior protection along with the grease coating as said by laffeaux.
    Thanks for the advice, everyone. I do cross somewhat deep creeks a few times a month on my AL full-suspension bike, and I hadn't really worried about it -- the mud that covers the bike on a weekly basis takes a toll on drivetrain, pivots, and bottom bracket. I figure the wear and tear is unavoidable.
    Now I have another step when cleaning up the bike post-ride -- pull the seatpost and turn the bike over. Thanks, +rep for all!
    Dec 2011
    I abuse my steel frame in every way possible. Then again, I bought it for $10. However, i think the chances of rusting out a BB are really low unless you are biking in salt water, and worse case scenario would be having to get a threadless BB.
    Reputation: OneEyeMan's Avatar
    Aug 2005
    Drill a hole in the bottom of the bottom bracket shell for drainage.
    Lenny
    Bike Freak
    Reputation: jgerhardt's Avatar
    Quote Originally Posted by formicaman View Post
    I abuse my steel frame in every way possible...
    Isn't that the only way to ride a bike?
    Quote Originally Posted by Lenny View Post
    Lenny
    It might be a good idea to tap the hole and then insert a screw to help keep out any excess water.
    My bikes [Fe][C]ycles
    Dec 2010
    My steel fixie see's rain, snow, mud, creeks, actually got transported in the rain twice last week, and while I'm going to use some frame saver before the next riding season I don't have any worries of my frame rusting out.
  1. Broken Steel Frame at top tube weld...3rd ride
    By gearwhine in forum Frame Building
    Last Post: 08-04-2010, 08:01 AM
  2. New steel fork, old steel frame question
    By Fleas in forum Niner Bikes
    Last Post: 06-01-2010, 09:08 PM
  3. Heavy Rider frame.... To steel, or not to steel??
    By hinybuder in forum All Mountain
    Last Post: 06-02-2008, 04:37 PM
  4. Need for Frame Saver for a new Steel Ride?
    By g-bike in forum Bike and Frame discussion
    Last Post: 12-30-2007, 11:26 AM
  5. MTB Festival, Pisgah Ride, Win a Haro Frame, Fox Fork Cane Creek Wheels
    By timbercomp in forum North & South Carolina
    Last Post: 08-21-2006, 09:01 AM
