Do I need my fork socks/boots?- Mtbr.com
Results 1 to 7 of 7
    May 2010
    I am currently riding a year 2000 specialized hardrock comp with the original fork. I currently have the socks/boots on but I have been wondering about the amount of travel that happens during certain points of my ride. Does any know whether the seals on the fork might be good enough to take them off if the fork is too old to risk exposing the stanchions. Thanks for your advice.
    WIthout knowing the model of fork, it's hard to say, but i'd leave them on.
    May 2010
    The model is rock shox jett xc, sorry forgot to add that.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Depending on your riding conditions and attention to maintenance you could probably get away with taking them off, but I'd just leave them alone.
    Stanchion boots are kind of a double edged sword. On one hand, they ideally keep contaminates out. On the other hand, if they are cracked or damaged, or are poorly designed, they can trap dirt and grit near the stanchions and make things worse.
    Does your Jett have a coil / MCU design, with no rebound or compression fluid? If so, the boots aren't terribly essential.
    Best advice I have is to pop the boots off on one end, clean them inside and out (and the stanchions as well), and pop them back into place. Check the boots for cracks and other damage.
    Reputation: Dremer03's Avatar
    I think fork books or shock boots are a bad idea. Stuff always gets under them, and its like rubbing sandpaper on the stanchions.
    Big Foot Blue KHS XC704r
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Boots are needed on some of the earlier Rock Shox stuff because the seals are not designed to keep dirt and other contaminants out .
