Results 1 to 6 of 6
Thread: DhX2
    Aug 2018
    DhX2
    Hi, I just got a new bike (Santa Cruz nomad cc custom build) and it has a DhX2. Iím new to coil and just before had a Rockshox deluxe. I have been playing around with the high and low speed damping, I have the rebound set right but the high and low speed Iím not so sure about. I know how they work but donít know how to set it up, Iím 58kg and have a 450 spring which should be a bit hard for me. If I bounce on the shock hard should I be able to bottom it out, and should I add lsc.
    cheers guys.
    Aug 2018
    If you were wondering I have the high and low speed compression on about 15 clicks from fully closed which is a bit on the harder side.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by Wogboy191 View Post
    If I bounce on the shock hard should I be able to bottom it out.
    No.
    Aug 2018
    How should I set it up since everything is on the firm side??
    Cheers
    Yeah, I'm that a$$hole.
    Reputation: Guy.Ford's Avatar
    Maybe this will help? - https://www.ridefox.com/dl/bike/605-00-182_RevA.pdf
    Might also want to play around with this or call fox about spring rate, 450 sounds high for a 128lb rider - https://www.ridefox.com/fox_tech_cen...alculator.html
    These are both good jumping off points.
    #THELEGENDMTB
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    Aug 2018
    Hi I just checked it out, I donít want to go to a heavier spring so can this be achieved with damping, because I have the high and low speed relatively hard. Although I could possibly add a click or two
    Cheers
  1. Fox DHX2
    By LCW in forum Shocks and Suspension
    Last Post: 05-17-2017, 07:06 PM
  2. Fox Float X2 vs Fox DHX2
    By cfrench in forum Shocks and Suspension
    Last Post: 05-12-2016, 09:21 AM
  3. Anyone running new Fox DHX2 SLS Coil?
    By avidtest in forum Evil Bikes
    Last Post: 05-01-2016, 01:47 PM
  4. Fox dhx2 vs push factory rc4
    By jimarin in forum Downhill - Freeride
    Last Post: 12-14-2015, 05:15 PM
  5. Push ELEVENSIX VS FOX DHX2
    By StarkhŁnd in forum Shocks and Suspension
    Last Post: 09-23-2015, 04:55 PM
Members who have read this thread: 29
