Critique build please (sentier vrx custom/san quentin 1) enduro/all mountain hardtail- Mtbr.com
Results 1 to 13 of 13
    Aug 2018
    Hi y'all. I've been harboring this deep desire for a hardcore/aggresive hardtail for as long as I've been into mt biking. I can't take my lack of a proper shredder no more so here goes nothing... (kindly advise on any potential compatibility issues or so. Cheers.
    The shopping list
    Vitus Sentier VRX+ 27.5" Hardtail Frame 2018 http://www.chainreactioncycles.com/us/en/vitus-sentier-vrx-27-5-hardtail-frame-2018/rp-prod161854
    Fulcrum Red Power 27.5" Centre Lock Boost MTB Wheelset (12 x 148) http://www.chainreactioncycles.com/us/en/fulcrum-red-power-27-5-cl-boost-mtb-wheelset/rp-prod171498
    Shimano
    BR-MT400 Disc Brake Set
    https://www.bike-discount.de/en/buy/shimano-br-mt400-disc-brake-set-721585
    RockShox Sektor Silver RL 27.5" Solo Air 140 Tapered Boost https://www.bike-discount.de/en/buy/rockshox-sektor-silver-rl-27.5-solo-air-140-tapered-boost-723950
    NX 1x11-fach Group Trigger GXP 170mm 32T https://www.bike-discount.de/en/buy/sram-nx-1x11-fach-group-trigger-gxp-170mm-32t-643032
    Cube Seatclamp 34.9mm https://www.bike-discount.de/en/buy/cube-seatclamp-34.9mm-606226
    Shimano Adaptor SM-MA-R160P/S rear 160mm postmount https://www.bike-discount.de/en/buy/shimano-adaptor-sm-ma-r160p-s-rear-160mm-postmount-27265
    Shimano Adapter SM-MA-F180P/P2 for Front 180mm https://www.bike-discount.de/en/buy/shimano-adapter-sm-ma-f180p-p2-for-front-180mm-37435
    Schwalbe Tube AV 19 for 29/28/27.5" https://www.bike-discount.de/en/buy/schwalbe-tube-av-19-for-29-28-27.5-31697
    Ritchey Grip-Plugs TR Logo 15-17mm https://www.bike-discount.de/en/buy/ritchey-grip-plugs-tr-logo-15-17mm-582209
    Maxxis Minion DHR II Rear WT 27,5 x 2,40" TR EXO Dual Folding https://www.bike-discount.de/en/buy/maxxis-minion-dhr-ii-rear-wt-27%2C5-x-2%2C40-tr-exo-dual-folding-529756
    Maxxis Minion DHF Front WT 27.5x2.50" TR EXO Dual 60 Folding https://www.bike-discount.de/en/buy/maxxis-minion-dhf-front-wt-27.5x2.50-tr-exo-dual-60-folding-543689
    WTB Volt Race Saddle (142mm) https://www.bike-discount.de/en/buy/wtb-volt-race-saddle-572302
    Cube Enduro 45mm Stem 0į https://www.bike-discount.de/en/buy/cube-enduro-45mm-stem-0-733376
    Cube Flat Race Pro 31.8x720mm Handlebar https://www.bike-discount.de/en/buy/cube-flat-race-pro-31.8x720mm-handlebar-733483
    Shimano
    Deore Disc Rotor SM-RT64M 180mm Center Lock
    https://www.bike-discount.de/en/buy/shimano-deore-disc-rotor-sm-rt64m-180mm-center-lock-30281
    Shimano
    Deore Disc Rotor SM-RT64 160mm Center Lock
    https://www.bike-discount.de/en/buy/shimano-deore-disc-rotor-sm-rt64-160mm-center-lock-255686
    Cube Seatpost GM 31.6x400mm no baseplate https://www.bike-discount.de/en/buy/cube-seatpost-gm-31.6x400mm-no-baseplate-682707
    Ritchey Comp Drop In Taper IS42/IS52 10mm https://www.bike-discount.de/en/buy/ritchey-comp-drop-in-taper-is42-is52-10mm-162367
    For the wise ol' riders in the house, am i better off with this or should I buy the San Marin quentin 1.0? I aim to ride enduro/all mountain
    Jan 2009
    I would go with neither and instead look at the Octane Pro for its thru axle rear end. Everything else about the frames are similar. Btw, you don't need a rear brake adapter, just front. And the frames you picked out are QR not thru axle. The wheelset you picked is boost 148mm, def will not work. The frame below is 142mm thru axle.
    Octane One Prone 27.5" Frame 2018 | Chain Reaction Cycles
    Aug 2018
    Thanks for your advice. however, i checked the sentier vrx full bike spec sheet and it runs 148 x 12 mm rear hub or did I miss something? Vitus Sentier VRX Hardtail Bike - XT 1x11 2018 | Chain Reaction Cycles
    Jan 2009
    Quote Originally Posted by vallee View Post
    Woops, my bad. I was looking at the cheaper frame. Also, you will want to look at a wheelset with wider rims. Those Fulcrum use very skinny rims. That said, those great prices on those frames.
    Aug 2018
    No problem. Any suggestions for affordable wheels? Had my eyes on these.
    https://www.bike-discount.de/en/buy/...eel-set-635892
    https://www.bike24.de/p1224886.html
    Jan 2009
    The Spline 30s look good on paper but they fair pretty poorly in the real world. The reviews on mtbr are abysmal. I dunno man, wheels are tough to buy which is why I build my own. Are you are somewhere in the EU? No point in linking US shops I think?
    Aug 2018
    I would appreciate it. any link is fine. I can ship.
    PS: Everything on the san quentin 1 appeals to me except for the coil fork. is a coil spring accepatable at that price range? I weigh 65kgs.
    Jan 2009
    mbtr member
    Reputation: scottzg's Avatar
    Building up a frame at this price point is is a complete waste of time. You won't save any money and the parts aren't good enough to be worth cherry picking. Budget wheels suck, those forks both suck, NX sucks.
    A through axle is either no advantage or a disadvantage on a hardtail.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Jan 2009
    Got a link to that bike? Generally it is best to buy a whole bike since you get more for your money. The costs of building a bike piecemeal is quite high because of the labor, time, and tools required not to mention the experience needed. Thus buy a whole bike if you can.
    Have you seen the Cube on CRC btw?
    Cube Reaction TM 27.5 Hardtail Bike 2018 | Chain Reaction Cycles
    Reputation: Lone Rager's Avatar
    Dec 2013
    ^^^ I pretty much agree with the two previous posts with at least one caveat. Some find it fun and enjoyable to choose parts and assemble a bike even when there may be no significant performance benefit in doing so, and even if it costs them something more than buying an equivalently performing complete bike. Nothing wrong with that.
    Do the math.
    Aug 2018
    Thanks everybody. I'll keep you posted on my final build.
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    I built up an Octane One Prone 29er over the summer. I definitely love how this bike handles. It descends like a raging monster and I've done crazy stuff on this bike that I never tried on my old FS Stumpy.
    Critique build please (sentier vrx custom/san quentin 1) enduro/all mountain hardtail-img_1111_zpsbxgqsaql.jpg
    Installed stuff:
    PNW Components Rainier IR dropper
    PNW Components Range stem
    PNW Components Range handlebar
    PNW Components dropper remote
    (I am from the PNW hence all my PNW Components gear)
    Fox 34 Factory 130mm fork
    WTB Volt Comp saddle
    Hope Pro 4 Enduro wheels (replacing with custom Stan's Flow rims/Bitex hubs this week)
    Cush Core (will install on new wheelset)
    2.3" Maxxis Minion DHF and DHRII tires
    Shimano XT drivetrain
    Shimano XT brakes
    Cane Creek headset (the head tube is fully integrated)
    If you want additional information about this frame, shoot me a PM! I have additional photos on my Instagram: jetblast117
    Trek …monda SL6 | Intense Recluse
  1. Marin San Quentin
    By BrettG in forum Marin
    Last Post: 3 Weeks Ago, 02:12 PM
  2. San Quentin 3
    By Jgus0025 in forum 27.5
    Last Post: 09-26-2018, 03:09 AM
  3. Anyone familiar with a Vitus sentier vrx?
    By Trying not to crash in forum Custom Builders & Other Manufacturers
    Last Post: 05-17-2018, 10:57 AM
  4. Replies: 44
    Last Post: 02-27-2014, 10:49 PM
  5. Replies: 18
    Last Post: 03-11-2008, 12:21 AM
Members who have read this thread: 4
