Results 1 to 8 of 8
    Dec 2014
    Cracked bolt hole in crankset - is there a cure?
    My XT crankset is cracked in one of the four bolt holes.
    Is there a way to fix this?
    I have understood that there is a zink method for diy soldering/welding on aluminium?
    2011 Stumpjumper FSR Elite, 650b conversion
    1996 Stumpjumper M2, 26"
    2013 Cube Limited Race, 29"
    2014 Cube Peloton Road Bike
    Reputation: yogidave's Avatar
    The only fix I can think of is eBay
    Dec 2014
    Elaborate please
    I was being a smart ass. There’s no cost effective solution to this. Better off buying a replacement. I bet you could find one on eBay (lovingly used) for not much.
    Alternatively, you could do nothing if the other 4 bolt holes are OK. That kind of damage is probably from an impact. In which case, it might make sense to not use it. Cracks like to grow.
    Dec 2014
    Quote Originally Posted by yogidave View Post
    What about this technique? As I understand it, any solid 100% zink material can be used, not only these brazing rods:
    https://www.youtube.com/watch?v=3SBfP4_i1Go
    You could look for a welder in you area
    Dec 2014
    thanx but I am looking for super cheap fix on this one. Have som zinc bits laying around the shed that I will experiment with.
    Reputation: sturge's Avatar
    Worth a try but aluminum quickly develops an oxidized layer at the surface when exposed to air. To properly repair you would need to grind out the repair area immediately before brazing/welding. Will never be structurally as strong...band-aid at best. You still have 3 of 4 bolts for chain-ring...depending on how hard you pound it you may be fine as is (for awhile).
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...
  1. is there a cure for shimano br-445 pad shifting?
    By chadohoag in forum 29er Bikes
    Last Post: 05-29-2014, 10:41 AM
  2. Formula T1 noise, is there a cure?
    By Finksta in forum Brake Time
    Last Post: 06-10-2013, 01:18 PM
  3. Problem with seatpost bolt pulling through bolt hole
    By rjr19146 in forum General Discussion
    Last Post: 01-21-2013, 05:54 PM
  4. 32 hole hub x 28 hole rim?
    By drMP in forum Wheels and Tires
    Last Post: 08-13-2012, 09:24 AM
  5. 36 hole or 32 hole?
    By G-Ryder in forum Wheels and Tires
    Last Post: 01-19-2012, 06:04 AM
