Is this a crack?- Mtbr.com
Results 1 to 14 of 14
    Is this a crack?
    Its small, but it worries me. Is this a crack. It doesnt seem to be an impact because the crack creeps through the complex shape of the caliper boss. Taking it to my LBS tomorrow.
    Scrape off the paint, drop in some food coloring, look at it with good light and a magnifying glass. Looks like something scratched the paint and the resulting corrosion pushed up some paint on the sides. Iff all good, use nail polish to fix the paint.
    From your photos, it looks like a fiber trapped in the paint. Get out your magnifying glass (or take additional photos and blow them up) and take a closer look at it.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Looks more like just a surface imperfection than a crack.
    Less isn't MOAR
    Cracks don't stick up above the surface they're in. That is something either in the paint or that was on the surface and painted over.
    Has it always been there? If so, not a crack. If it is new, it IS a crack. Looks like a crack to me...scape the paint off, at the LBS, and see! How long have you owned the frame?
    Dec 2010
    I agree with a fiber under the paint and the fact that a crack wouldn't protrude like that. And a crack wouldn't be intermittent, like in the picture. Besides, I can't imagine a crack happening in that spot. Maybe running along the boss, or the leading end of the boss, but not there.
    namagomi
    Reputation: electrik's Avatar
    Quote Originally Posted by jlmuncie View Post
    Cracks can "stick up" particularly if the paint is peeling. I think the best option is just to sand it down by hand with some super-fine grit paper. It looks suspicious to me because it's above the weld and crosses a bend in the material. All higher stress location.
    The way that's formed, its not even lined up to be a crack. Its not in a stress area or directly facing the weld bead and can only spread onto thicker material. If there was enough stress to cause a crack like that it would more likely be up where the bolt hole is or to the right parallel to the weld bead.
    Dec 2010
    Quote Originally Posted by 3mpach3r View Post
    Exactly.
    And craks don't stick up like that. Yes the paint can come up, but it will start to curl up and peel farther from the crack. Nothing like what is pictured.
    what crack?
    2013 Ibis Mojo HD Special Blend with dropper post, hope/stans wheelset and hope x2/m4 brakes
    www.bigrobracing.co.uk
    Reputation: robdeanhove's Avatar
    Dec 2005
    As above, definitely not a crack.
    Take a breath of relief and go enjoy riding your bike! :-)
    Reputation: Bicyclelist's Avatar
    not a crack
    namagomi
    At least it's not a tumor...
  1. paint crack or frame crack?
    By fujibikeben in forum Frame Building
    Last Post: 10-16-2011, 07:53 PM
  2. Frame crack or paint crack?
    By Rad Rider 415 in forum Niner Bikes
    Last Post: 05-06-2011, 07:20 AM
  3. Replies: 7
    Last Post: 05-26-2010, 02:17 PM
  4. So within one year another crack!!! & same type of crack
    By arielDB in forum Bike and Frame discussion
    Last Post: 05-09-2010, 02:20 PM
  5. crack or what???
    By Mandango in forum Turner
    Last Post: 03-18-2006, 11:31 PM
