Results 1 to 14 of 14
    Nov 2017
    Bike transporting..avoiding frame damage
    I used to have a hardtail. Now I have switched to a full suspension but now the transbike holds the bike by the rear frame piece. Do you think that over time it could damage it somehow? links frame tc. See pics..last pic is todays ride
    Sent from my SM-G935F using Tapatalk
    Reputation: Junersun's Avatar
    Jun 2014
    Probably not unless you take it through some rough stuff. You'll probably get some rub marks though.
    I do like holding a bike by the wheels though. Enjoy your squishy bike!
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
    Reputation: Ray Lee's Avatar
    You could pad it so you dont get the paint rubbed off, or buy a top tube adapter
    https://www.biketiresdirect.com/prod...CABEgIDjvD_BwE
    I have had a couple close calls with light weight clip and strap racks so maybe upgrade to a better rack (yours might be solid, just looks like it could be one of the more flimsy types from the picture)
    Nov 2017
    its solid but its an entry level one. ill just switch to another rack type as soon as I can I guess
    Nov 2017
    Quote Originally Posted by Junersun View Post
    Pics of the holder?
    Reputation: Mr Pig's Avatar
    The way you have it mounted in the picture, yes.
    You need to have foam or rubber between all parts of the rack and bike that contact each other. Foam pipe insulation is ideal. Put it on the rack arms and cover with ductape. When mounting multiple bikes, foam can be placed on frame areas than make contact with each other.
    Then use bungie cords to hold the bikes tightly to the rack so that they cannot bounce around. You can't have too many straps!
    Jun 2014
    Quote Originally Posted by syndragon View Post
    Pics of the holder?
    1up rack.
    Current Bikes
    2016 YT Tues AL
    Pics of the holder?
    Probably like this, something to hold the wheels
    Bike transporting..avoiding frame damage-saris-bones-3-installation-saris-superbones-thule-t2-pro-thule-t2-pro-xt-assembly.jpg
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    ^^ Works pretty good with most bikes I think.
    I got the Yaki version called a 4-timer I think. I like the stability of it, bikes very secure and I DO add a few bungee loops here and there for insurance sake. Also found assorted colors of 3M electrical tape and wrap the top tube where the over-hook fits. Found an orange-red that matches the bike so well it's invisible.
    Meantime, I don't think your current rack will hurt the suspension system if the bike is on there that way and supported so close to the pivot but I understand these things get in your head and long term worry isn't worth it.
    With a nice bike or a few in the family, it's not difficult to justify a rack that's a bit more pricey IMO.
    In the Middle Ages, the biggest mistake was not putting on your armor because you were 'just going down to the corner.'
    Reputation: sturge's Avatar
    I have a pickup but if I was in your situation I would make a trip to Home Depot...apply foam piping insulation to rack where bike contacts it. Cheap/easy.
    https://www.homedepot.com/p/Everbilt...7812/204760815
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...
    I lent my tail-rack to a friend years ago and he very tidily wrapped foam on it before giving it back, very nice of him ;0)
    No known cure
    Reputation: Vader's Avatar
    Can you offset the arms? I did this with a Rhode Gear tire mount rack on my Jeep. I have to put the bike on driveside in, but it's centered and cradled by the main triangle.
    Ripping trails and tipping ales
    Nov 2017
    Quote Originally Posted by sturge View Post
    now this is a simple and cheap solution...thanks. ill definitely try this out.
    Nov 2017
    Quote Originally Posted by Mr Pig View Post
    thanks dude, ill do this asap.
  1. Winter bike rack....avoiding rust.
    By cleopatra999 in forum Cars and Bike Racks
    Last Post: 03-03-2016, 12:26 AM
  2. avoiding friction burns
    By goodmojo in forum General Discussion
    Last Post: 03-05-2013, 11:01 PM
  3. Avoiding import tax when bringing a bike from the USA
    By Steve71 in forum Australia, New Zealand
    Last Post: 05-31-2011, 09:10 AM
  4. Avoiding sickness - anyone had success?
    By Johnny K in forum XC Racing and Training
    Last Post: 02-14-2011, 09:49 PM
  5. 2x10 avoiding crosschain?
    By liberatorx in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-24-2011, 09:29 PM
