Results 1 to 5 of 5
    Mar 2017
    add more rebound to old fork
    how do i add more rebound to a recon gold rl 2011 fork ? i overhauled it and would like abit more rebound can i just add more oil than the values from sram?
    Reputation: Mudguard's Avatar
    Heavier weight oil. Used to be more common in the open bath days.
    Mar 2017
    heavier in the compression chamber? i added 5w to it and 15w to rest
    Reputation: Lone Rager's Avatar
    Dec 2013
    More oil won't increase damping. Heavier weight oil will. The oil in question is in the damper, not on the air spring side. The recommend volumes should be adhered to. If open bath, remove the lowers, drain out the oil, cycle the damper to purge existing oil. If a cartridge damper, you gotta purge, fill and bleed the damper, which you would have done if you overhauled it.
    Do the math.
    Reputation: WHALENARD's Avatar
    Feb 2010
    If using fork oil pay attention to the actual viscosity with a chart like this.
    https://transmoto.com.au/comparative-oil-weights-table/
    *I'd also add that increasing oil volume could potentially require more rebound, especially on big hits.
    It is no measure of health to be well adjusted to a profoundly sick society.
  1. Replies: 6
    Last Post: 11-06-2017, 04:22 AM
  2. For a 200lb rider, more rebound or less rebound?
    By liftmys10 in forum Shocks and Suspension
    Last Post: 11-02-2011, 03:11 PM
  3. add add'l turner to stable?
    By seandm in forum Turner
    Last Post: 05-07-2006, 04:15 PM
  4. Rebound, Rebound, Freakin Rebound
    By Moo Shoo Pork in forum Shocks and Suspension
    Last Post: 02-09-2005, 09:44 AM
Members who have read this thread: 17
