2008 Titus Motolite shock length- Mtbr.com
Results 1 to 5 of 5
    Anyone with a 2008-vintage Tutus Motolite, PLEASE measure for me the SHOCK UNCOMPRESSED LENGTH, or the bench length eye-to-eye. Hoping it's 7 1/2", but I need to know because the shock I've been intending to mount for some time now is 7 7/8".
    My frame size is XL, but I think the shock length would be the same for M-L-XL.
    J:
    Reputation: Deerhill's Avatar
    Dec 2009
    My ML didn't use 7.5, i'm positive it's the longer shock unless they revised it over the years
    One thing to watch out out for, some of those air shocks allow too much travel. Take the air out and make sure the seat stay brace doesn't contact the seat tube
    Quote Originally Posted by DeerhillJDOG View Post
    You're SURE it wasn't 7.5? If you're sure it was the 7 7/8", I'm all set. I was afraid the spec was for 7.5, because i have a 7.5 Fox RP23 that I could have SWORN came off the Titus frame, and a 7 7/8 Manitou I was running on it that I KNOW wasn't stock. I was afraid I was running a shock that was too long.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by goonboy View Post
    Pretty sure it is 200mm x 51mm (7-7/8"x2")
    Older 80mm travel RX frames used a shorter eye to eye shock.
    mtbtires.com
    J:
    Dec 2009
    Positive, think the only other shock size for ML was 6.5" for the small frame
