XTR Bottom Bracket and SLX Crankset- Mtbr.com
    Jan 2011
    Will a SLX crankset work with an XTR Bottom Bracket?
    I like turtles
    Reputation: TiGeo's Avatar
    Bottom brackets/cranks have gotten so confusing that the best thing for these type of questions without lots of detailed measurements is to have you LBS deal with this to make sure you get the right things.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro AF
    Before you change your SLX bb how about doing maintenance instead.
    Pull the crankset out, easy with a rubber mallet tap needed sometimes.
    On each side is a black plastic cover with Do Not Remove on it.
    Using a thin blade knife get under the outside edge, gently push in and out past the edge at another point, say 3 o'clock and 12 o'clock.
    Pry light to get a small amount of beginning movement. Repeat at 3 and 6, etc. and work the cover off. You can crack it if you try to pry too much at one spot.
    Carefully pry off the bearing seal you now see from the inside edge going around in steps. Do both sides.
    Stuff tissue in and repeatedly flush the race and ball bearings with Liquid Wrench or Kerosene until it they spin smoothly again.
    Take out the tissues.
    Test with the crank.
    Load it up with wheel bearing grease.
    Press on the bearing seal.
    Snap on the plastic cover. Tighten that plastic non-drive fixing bolt when you assemble the crankset.
    You won't be needing a XTR bb.
    Reputation: 11053's Avatar
    Quote Originally Posted by millsj2 View Post
    Yes.
    You just need t match up the correct crank + spindle with the correct BB type.
    XTR BB93s are great.
    $35 give or take and a 3 year warranty.
  1. Bottom Bracket and Crankset advice
    By triple66 in forum Singlespeed
    Last Post: 03-23-2015, 07:41 AM
  2. New Crankset for PF30 Bottom Bracket
    By mattyk85 in forum All Mountain
    Last Post: 07-05-2013, 02:44 AM
  3. Crankset/bottom bracket question....HELP PLEASE
    By nelsonccc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-20-2012, 10:00 AM
  4. xtr 951 crankset 952 bottom bracket
    By zindog in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-28-2012, 07:51 PM
  5. Bottom Bracket/crankset compatibility
    By VandaL in forum Beginner's Corner
    Last Post: 03-28-2012, 11:50 AM
