Why did my back wheel keep ending up like this tonight?- Mtbr.com
Results 1 to 8 of 8
    Reputation: BillClinton's Avatar
    Jul 2014
    Happened 3 times that I noticed. It would be super crooked as seen in the attachments, and then my quick release would also be a bit loose. I would undo the QR, reset my wheel, redo the QR as tight as I could...and then it would happen again. I know my derailleur hanger is a bit bent but would that make it do this? Please help, I'm still a maintenance noob trying to learn. Thanks!Why did my back wheel keep ending up like this tonight?-imag0275.jpgWhy did my back wheel keep ending up like this tonight?-imag0274.jpgWhy did my back wheel keep ending up like this tonight?-imag0273.jpg
    Reputation: J.B. Weld's Avatar
    I bet the skewer is an open cam design, if so I'd get a Shimano or equivalent and in the meantime put a few drops of oil where the skewer lever pivots on the curved washer which will usually allow them to clamp down tighter.
    Jul 2014
    Quote Originally Posted by J.B. Weld View Post
    It is in fact an open-cam. Is there a certain model that's the "best bang for buck?"
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Maybe the threads on the skewer are busted.
    It happened to me once. It caused the nut to slip and loosen.
    Pretty well any Shimano skewer will work and are good. I always replace the rear skewer and have started doing the front too.
    If you have a bike co-op around your area check their box of skewers. I have picked them up for a couple of bucks, expensive at the LBS.
    Rollin' a fatty
    Reputation: DiRt DeViL's Avatar
    Salsa or Shimano XT skewers work very well.
    Reputation: thickfog's Avatar
    Oct 2010
    Re: Why did my back wheel keep ending up like this tonight?
    Use these. Strong and look cool.
    http://www.halowheels.com/products/part/HUHAQHD
    As long as you bring your multi tool you can undo them if needed.
    Been great for me on Pugsley and krampus with track ends and zero movement. Between. $12-18 USD.
    If not as everyone says Shimano skewers are awesome.
    CRAMBA Chairman
    Jul 2014
    Awesome, thanks for the help guys. Someone mentioned my dropouts may be bent due to my hanger being bent. Hope that's not the case.
  1. Why did my back wheel keep ending up like this tonight?
    By BillClinton in forum Wheels and Tires
    Last Post: 08-01-2014, 08:43 AM
  2. Back wheel stopped clicking.
    By wayney1233 in forum All Mountain
    Last Post: 07-30-2014, 08:35 PM
  3. Replies: 2
    Last Post: 06-24-2014, 07:03 AM
  4. Ending Bracken Mt ride at Dugan's...getting back to camp?
    By RDU Goldfish in forum North & South Carolina
    Last Post: 07-12-2013, 01:50 PM
  5. Replies: 0
    Last Post: 11-29-2011, 10:13 AM
