Wheel shifting during braking- Mtbr.com
Results 1 to 11 of 11
    Oct 2010
    Hello fellow mtbr's -
    I recently put a new fork (Manitou Drake) and a front brake (Avid BB7) on my bike. I was riding around testing out the new setup and noticed that while braking, the wheel shifted to the left. I undid the quick release and reset the wheel where it should be, but it happened again each time.
    Any ideas what the problem could be?
    Newborn Rider
    hub bearing is loose?
    Reputation: Eville140's Avatar
    Make the quick release tighter.
    Oct 2010
    I thought it was the quick release also, but I tried it pretty tight so i'm not sure if thats the problem
    Reputation: sanjuro's Avatar
    Sep 2004
    Look at the dropouts closely after you put the wheel in. Possibly there is a bent dropout or the QR is contacting the lawyer tab.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    And make sure you aren't closing the QR lever against the fork leg. It needs to close fully and you can do that if you close it against anything.
    CT3
    CT3 is offline
    Hoodwink
    Reputation: CT3's Avatar
    May 2010
    make sure the cups on your hubs arent lose, just hand tighten them
    Reputation: jpeters's Avatar
    What wheel is it ?
    Oct 2010
    Just the stock wheels - 2011 Giant Revel 1
    Your problem is most likely just the wheel flexing. I had some low end wheels that would flex under power.
    Oct 2010
    I dont think thats it because it never happened with the old fork and brakes. And also because when I go to reset the wheel in the dropout, its not exactly where it should be (centered in the dropout like I set it).
    I'll try to make a video of it this weekend
