What spoke wrench to get?- Mtbr.com
Results 1 to 8 of 8
    Should I start with a cheap simple multi spoke wrench, like an Avenir, and later upgrade to a set of Park spoke wrenches?
    After I upgrade, I could put the cheaper wrench in the tool pouch on my bike.
    Reputation: 05kas05's Avatar
    i would just buy the park wrenches to start with it never seems to fail when i try to cheap out on stuff like tools i almost always end up having to buy the good ones anyway for one reason or another. i would then get a multi tool for the bike i believe the topeak mini 18 i carry has two spoke wrenches on it plus everything else i would need for most trailside repairs.
    surly karate monkey
    surly ogre
    I don't carry a spoke wrench when riding. If you damage a wheel so bad that you can't ride back to a trailhead, a spoke wrench isn't going to help.
    Oct 2011
    Spokey - DT Swiss. Awesome tool, just makes you want to build another wheel. Light too, if you want to carry one while touring etc.
    I'm a big fan of the Park spoke wrenches, and have used them for years and built many wheels with them. You don't need to buy a set, though. Just buy the one you need.
    I generally only like to buy a tool once. Buy the one you like best.
    Be careful using it. My early experience with a spoke wrench was costly (a set of Ringle Bubba hubs and Mavic 231 rims). I'll disassemble my entire bike without a thought but I tend to leave my wheels to a pro. A bicycle wheel is a delicate balance of strength and fragility.
    Not trying to discourage you from learning the basics. Maybe you will become an expert wheelsmith. Just don't buy a spoke wrench and think it makes you a bike mechanic.
    When I ruined my wheels I tightened up a few spokes and set off for a ride. Heard a little 'tink' and realized later my hub had broken. A couple days later, the other one did the same thing.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    Generally speaking (for MTBers), get the black one from Park. If it doesn't fit your spoke nipples, get new wheels (kidding. . . . a little bit)
    Park Tool Co. SW-0 : Spoke Wrench : Wheel & Spoke
    or
    Park Tool Co. SW-40 : Four-Sided Spoke Wrench : Wheel & Spoke
    jeffj - your mind reading abilities are great! After reading BadMechanics post I was just about to ask which size to buy.
    groundoggy - Thanks for the advice! I never would have thought that hubs were that "sensitive". I just need to true my rim a little.
    Thanks!!
  1. What spoke wrench do I need?
    By gtp405 in forum Tooltime
    Last Post: 02-23-2009, 11:31 PM
  2. What is your favorite spoke wrench
    By urmb in forum Wheels and Tires
    Last Post: 01-10-2008, 07:35 PM
  3. Spoke Wrench
    By PanicFan77 in forum Beginner's Corner
    Last Post: 12-29-2006, 11:45 AM
  4. Best spoke wrench that isn't $50?
    By Homebrew in forum Wheels and Tires
    Last Post: 08-05-2004, 11:33 AM
  5. spoke wrench help please...??
    By bike_riot in forum Wheels and Tires
    Last Post: 06-02-2004, 07:45 AM
