what do you think about this bike?- Mtbr.com
Results 1 to 12 of 12
    what do you think about this hardtail bike.
    Frame AltairX Custom Butted-Aluminum Trail-Tuned POWER STAY frame, reinforced-gussetted downtube, sculpted rear dropouts with replaceable rear derailleur hanger, H2O boss, International Standard rear disc mounts. Rear rack mounting points.
    Fork 26" SUSPENSION FORK, ROCK SHOX DART2 W/TURN-KEY LOCK
    ALLOY BLACK CROWN, adjustable preload, DiscBrake postmounts
    Crankset TruVativ X-FLOW square taper or IsoFlow PowerSpline (cannot choose), Aluminum Triple 22/32/44T, 175mm
    Bottom Bracket Sealed Cartridge
    Pedals ATB Beartrap, resin body, metal cage
    Front Derailleur SHIMANO DEORE FD-M510, Top Swing
    Rear Derailleur SHIMANO DEORE SLX RDM-662SGS BLACK long cage (H normal / not rapidrise)
    Shifters SHIMANO Alivio SL-M410 Mega 8 Speed STI Rapidfire Pods (24 speeds total)
    Cassette/Freewheel SHIMANO CS-HG30-8I 11-30T
    Chain 8 Speed Z72 Narrow
    Hubs DiscSpecific Aluminum (black) Sealed Bearing mechanism
    Spokes 14G Stainless Steel
    Rims WTB Speed Disc Double Wall Aluminum disc specific
    Tires WTB Velociraptor Blackwall 26 x 2.10 (front and rear specific tread)
    Brakes TEKTRO NOVELA Mechanical Disc Brakes, Ventilated Steel Disc Rotors (round or wave/no choice)
    Brake Levers TEKTRO MT2.1 for Disc with aluminum lever
    Headset Internal Sealed bearing VP A71 1.125 inch
    Handlebar Comp Aluminum Riser, 25.4mm clamp diameter
    W:620MMxR:30MMx6 DEGREES
    Stem Comp Threadless Aluminum 1.125 inch
    Tape/Grip WTB Dual Compound Trail
    Saddle WTB Speed V Sport with comfort groove
    Seat Post Aluminum Micro-Adjust 27.2x300mm
    Seat Clamp Aluminum w/QR
    slap happy
    Reputation: istandalone's Avatar
    what's the price? what kind of riding will you be doing on it? seems to have decent components (save for the fork, those Dart's suck balls) and if the price is right, and it suits your terrain, then that's all you need and you're good to go.
    Consequences dictate our course of action and it doesn't matter what's right. It's only wrong if you get caught.
    its 419$
    It's easy to find out which bike has those components. Just google the first couple of lines.
    Someone recently got the 1500 and was happy with it. The only thing that would concern me is the weight. I believe he mentioned it weighs almost 35 lbs. At the same price, I would go with the Forge Sawback. It weighs much less. You can find plenty of info on both if you search.
    Jun 2010
    Quote Originally Posted by rlouder View Post
    It is the 2011 Dawes Haymaker 1500.
    My son rides one and it's a very good deal for Deore SLX ... the actual weight is 30 lbs
    https://www.bikesdirect.com/products.../hay1500xi.htm
    it weighs 30# but what size frame is it?
    Jan 2009
    If you don't have all the tools and skills to assemble and maintain that bike, factor into that cost what you will have to pay a bike shop to assemble and tune up the bike. most bike shops factor that into their prices too, they have to pay staff to do those things, so they cost a little more.
    Class Clown
    Reputation: dundundata's Avatar
    I don't think Darts are as bad as people say, although mine seemed to come from the factory without the proper oil levels. Once I fixed that it was ok. Yes that's right I have a Dart3 and it's halfway decent. Still if you can swing a Tora I'd go that route.
    I agree that Dart forks aren't so bad, at least for beginners. I have a Windsor Cliff 4500, and it has an RST Capa, which is like a pogo stick compared to the Dart 2 fork on my other bike. The downside of the Dart 2 fork is that it is HEAVY, but it seems to do the job for me.
    As far as the bike is concerned, its about the best bike you are going to get for that pricepoint. At some point, you may want to upgrade to a better frame, but for starting out, I don't see how you can go wrong.
    Reputation: Colo Springs E's Avatar
    Dec 2009
    Quote Originally Posted by dundundata View Post
    Does a Dart3 have oil??
    Class Clown
    Quote Originally Posted by Colo Springs E View Post
    it should!
    Dec 2009
    it should!
    Ha guess so!
