tyre choice help- Mtbr.com
Results 1 to 10 of 10
    tyre choice help
    hi guys
    i have a marin rocky ridge with hope hoops and maxis high rollers 3.35" on, but i want to burn some miles on the road with very little offroad while the weathers bad over the winter, just to keep a little fitness up.
    what tires do u recomend for road with little offroad thrown in as the maxis are bit big n chunky for the road. something nice n fast not bothered about cost etc
    thanks a lot for the advice if anyone can advise
    XC Ground Pounder
    Reputation: quietcornerrider's Avatar
    Just to clarify, you mean 2.35" right?
    I've known the Kenda Kwests to be a good slick tire, and if you want semi-slick, try the Michelin Country Rock. I like both of them.
    The Kendas are available in 26x1.5 @ 630gm and the Michelins available in 26x1.75 @ 560gm.
    Balls in your court.
    Well, since they gave us a KHS forum, I guess I have to come up with something else for a sig.
    bi-winning
    Reputation: rkj__'s Avatar
    Does winter road usage involve any snow or icing where you are?
    not really much snow UK. and yes the highrollers in 2.35" sorry typing error
    Reputation: JoelovesDirt's Avatar
    Kenda small block 8. Superfast rolling with some tread in case you go offroad.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by JoelovesDirt
    x 2
    too cold to ride
    Reputation: BigSharks's Avatar
    Quote Originally Posted by quietcornerrider
    Heh- I was going to recommend some motorcycle tires...
    I have the Country Rocks as my semi-slicks - they are really good (on road and very firm hardpack) and pretty inexpensive.
    Now go home and get your ******* shinebox.
    Can't feel my legs
    Reputation: JPark's Avatar
    If you're looking for a straight slick, +1 on the Kenda Kwest. They are super fast, and come in a 1.95 for more volume for hucking curbs and whatnot
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Maxxis Monorails roll real easy and not too bad off road.
    Less isn't MOAR
    Reputation: Hellrazor666's Avatar
    Maxxis Holy Rollers!! They are great on the street real fast rolling and if you adjust tire pressure they are ok on light off road
    1.. 2.. 3... 4...........FIFFFFFFF !!!!!!!!!!
