Tubeless Conversion on my old Wheels- Mtbr.com
Results 1 to 17 of 17
    Jun 2010
    I think
    Jun 2010
    it would
    Jun 2010
    probably
    Jun 2010
    work quite well
    Jun 2010
    I have stans
    Reputation: mass-hole's Avatar
    Oct 2011
    I have a set of Bontrager Corvair wheels on my '00 GF Tassajara. I need to get some new tires soon and keep hearing about the Pro's of tubeless(as well as the con's, burping, tires blowing off etc.) Would it be a bad idea to try and Stan's conversion kit on these wheels.
    FYI, I am not trying to be cheap,I have rear V-brakes and no mounts for a disc caliper on the frame and have yet to find a wheelset that is UST and vbrake compatible.
    2015 Intense Carbine 29
    2013 Motobecane Fantom Team DS
    Jun 2010
    and have had
    Jun 2010
    no problems so far
    Jun 2010
    seems pricey at first
    Jun 2010
    but pays for itself in the long run
    This
    Thread
    Is......
    Too
    Long
    Oct 2011
    Quote Originally Posted by ARCHAIC View Post
    This
    Thread
    Is......
    Too
    Long
    Your just jealous cause this is the fast growing thread ever
    Former Bike Wrench
    Quote Originally Posted by mass-hole View Post
    I would recommend going with either UST or Tubeless Ready (TNT, 2Bliss, TCS, etc) tires to give you the best chance of success. You could pay for the Stans rim strips (Standard) or try one of the Ghetto Methods. If you have access to an air compressor, the Gorilla Tape method may be enough. Simply tape the rim bed and make sure it is pressed down good and firm. Then punch a hole for the valve stem (cut one out of an old tube, removable core ones are best) and install it. Install the tire and pour in sealant right before you get the last part of the bead on the rim. Lubricate the beads with some soapy water and use the compressor to seat the tire onto the rim (don't exceed 40 psi). Shake the sealant around until the entire bead seals (no more soap bubbles) and you should be set to go.
  1. Easton XC One SS wheels - tubeless conversion?
    By AK47 in forum Wheels and Tires
    Last Post: 07-22-2011, 02:13 PM
  2. Tubeless conversion on I9 wheels
    By macming in forum Wheels and Tires
    Last Post: 02-25-2011, 11:44 AM
  3. tubeless conversion on 29er wheels
    By rob1208lv in forum 29er Bikes
    Last Post: 02-08-2010, 09:17 AM
  4. Replies: 47
    Last Post: 01-28-2010, 02:46 AM
  5. Replies: 4
    Last Post: 08-17-2009, 08:18 PM
