Which Tool for this ?- Mtbr.com
Results 1 to 11 of 11
    Hi fellas,
    Decided to post in the beginners instead of tools, cos i'm a beginner.
    Which exact Park Tool model do I need to remove this exact bottom bracket please?
    http://www.bikepedia.com/pa/Item.aspx?itemid=987048
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    There are a few 'nuances' to be aware of when doing this that could help ensure success:
    http://www.parktool.com/blog/repair-...et-service-bbt
    Dec 2010
    Sledgehammer and chisel. Stick corner of chisel in one of the splines and beat the **** out of it til it comes loose. Then use a giant pair of channel lock pliers to grip it and unthread it.
    Haro Sonix LT VL120
    Quote Originally Posted by sasquatch rides a SS
    OH BOY... did you repair bikes for cavemen???
    Dec 2010
    Quote Originally Posted by D-Avid
    Fellow 'squatches
    Come see me after class
    Dec 2005
    i'd use a flat blade screwdriver instead of a chisel. it's less likely to gouge the bottom bracket cup.
    Dec 2010
    Quote Originally Posted by alexrex20
    When I chip off one of the splines I just move to the next one...that's why they make them with a lot of splines right? When all the splines are gone it's time to replace the whole BB...isn't that how it goes?
    Dec 2005
    makes sense!
    Dec 2010
    makes sense!
    Duh.. I would know. I work in a shop.
    Quote Originally Posted by TheDoc46
    If you still have the crankarms installed, you may also need a crankpuller to remove them, like this:
    http://www.parktool.com/product/univ...d-cranks-cwp-7
    As for removing the bottom bracket, turn the left counter-clockwise (like all normal screws and nuts) to remove it. The right comes out in clockwise direction. Sometimes they can be really tight and you may need a breaker bar to drive your BB remover.
