Tires to get?- Mtbr.com
Results 1 to 11 of 11
Thread: Tires to get?
    Tires to get?
    i ride on the road nearly everyday but i also ride dh and xc.
    Reputation: ncblue's Avatar
    WTB Nano Comp is a good tire for trails and road. I wish I would have bought a few more when Performance had them for $6.99.
    I use IRC Mythos XC II for thre my trails, but I don't ride on the rode/greenway. The Nano did a great job on dry trails (not so good in the wet) and does great on the road.
    http://www.nashbar.com/bikes//Produc...2_208644_-1___
    Chris
    2005 Walmart Schwinn (slightly modified)
    Still going...
    TRANCER
    Reputation: Biohazard74's Avatar
    I like Kenda Nevegals. Although they don't roll as fast as some, I find that the grip like no other on loose rock, roots, and even mud and hardpack.
    Ride
    I ride mostly rail trails. Do you think i need knobbies or can I get away with a compromised road tire with relatively normal tread.
    Larry
    thanks for the advice
    Biohazard74 will the kenda nevegals last on the road?
    TRANCER
    Nope. The Nevegals are definately not good for the road.
    Ride
    any other suggestions?
    I know it's pain but have you considered switching tires depending on what you are doing that day? I personally have used the Kenda small block 8 on both road and xc but frankly any MTB tire is going to wear quick on asphalt compared to a road tire. It also depends on how much distance you will put on the tire. If your commute is like 2 miles, they should last.
    Just checking the kenda website. They also have these short tracker which have almost 0 knobs. I've never used them but they might be interesting to check out. Less knobs might wear better.
    http://www.kendausa.com/bicycle/John...ml#smallblock8
    Thanks i looked into the short tracker i might try them. Im probably going to change tires depnding on conditions then.
    Reputation: Hellrazor666's Avatar
    Well if you do wanna switch tires I can say Holy Rollers are awesome for road riding
    1.. 2.. 3... 4...........FIFFFFFFF !!!!!!!!!!
