Stem Raising- Mtbr.com
Thread: Stem Raising
    sid
    sid is offline
    Stem Raising
    Hey all again,
    Trying to raise my stem and not too sure how to go about this. My old bikes I would just loosen the stem center bolt, twist it loose and twist and raise. This FSR Specialized has 3 spacers under the stock stem with the center bolt also. Do I need to add spacers if I raise the stem? How far can I raise the stem? Thanks all. Does this work like with the old wedge piece connected to the stem?
    Sid
    tlg
    tlg is offline
    (enter witty phrase here)
    Reputation: tlg's Avatar
    Quote Originally Posted by sid
    Hey all again,
    Well you're sorta out of luck. Your stem looks like this right?
    If you have spacers on the top, then you can switch them to the bottom. But if they're already on the bottom, there's not much you can do. You could get away with adding 1-2 spacers, but then you start reducing the clamping area of the stem.
    Your only real option is getting a new stem with a larger rise.
    This here will show you how the threadless stem system works.
    https://www.parktool.com/repair_help...readless.shtml
    Feb 2005
    if you want to raise your bars
    Get another stem probably with a 15 angle, make sure you get one that's the right length for you, and also you can try riser bars, which come in many different variations. I would suggest going to your lbs and learn all you can from them before you buy anything. Good Luck.
    Domestic Fowl
    Reputation: FreeRangeChicken's Avatar
    Yeah, what they said....
    If you don't have spacers above the stem that can be moved beneath the stem you're stuck with changing to a stem with more rise, or going to a riser bar.
  1. 1 1/8" Quill stem trade anyone?
    By Carsten in forum Vintage, Retro, Classic
    Last Post: 03-11-2005, 07:06 AM
  2. Headshok stem doesn't fit Headshok!
    By Astroboy in forum Cannondale
    Last Post: 01-19-2005, 06:50 PM
  3. How does stem length effect steering?
    By BudhaGoodha in forum Downhill - Freeride
    Last Post: 12-09-2004, 02:01 AM
  4. Short stem
    By SpinWheelz in forum Singlespeed
    Last Post: 11-16-2004, 02:04 PM
  5. Need a HS stem quickly!
    By trukweaz in forum Cannondale
    Last Post: 06-05-2004, 10:32 AM
