Results 1 to 5 of 5
    Reputation: 40Acres's Avatar
    Squeaking Noise Coming From the Front
    Hey Guys,
    I was out riding the local trail last night and I started experiencing a squeaking noise when I turned the handlebars. It doesn't appear to be the shock, but I may be wrong. Anybody ever experienced this before?
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    I'll go with the weird suggestion first: it's probably your cables rubbing the frame. Put some electrical tape on the frame where the cables contact anything and ride it around, if it stops squeaking then you've found your issue. If it is the cables, then you could stick with electrical tape (I do) or you could get some fancy frame protector patches.
    Otherwise, make sure your headset is adjusted properly.
    Quote Originally Posted by zebrahum View Post
    Thanks for the advice...I'll check it when I get home.
    Nickel Havr
    Reputation: Eckstream1's Avatar
    Also check your front quick release...
    My front brakes will squeek if the quick release isnt tight enough...
    Quote Originally Posted by William Blake
    Great things are done when men and mountains meet. This is not done by jostling in the street .
    Jun 2012
    I second this, I had squeaking that I tracked down to my cables rubbing together when I turned the handlebars.
    Sent from my ADR6425LVW using Tapatalk 2
