service of fork...guides and more guides- Mtbr.com
Results 1 to 5 of 5
    Mar 2011
    Good job! service of fork...guides and more guides
    So i going to service my rockshox tora 302 fork on my rockhopper tomorrow and been looking at all the guides/manuals
    Problem is there so many and many have different views on how to do it i need some advice from those who have done service with simular fork.
    questions:-
    Is it worth removing the lower leg seal+Foam rings?
    And if not can i spray isopropyl alcohol/degreaser into the lower legswith the seal+foam ring still inside without worry as manual seems to says?
    If i do remove the lower leg seal/foam ring, can it be done this way,Part 4-8.??
    (http://www.bikemagic.com/maintenance...cing/3253.html)
    Ie without needing a "special seal insertion tool"
    That all, i know where to put grease ie springs/seals and only small amounts
    cheers if anyone can help
    Former Bike Wrench
    If your seals are not leaking, then leave them alone except cleaning and lubricating.
    Mar 2011
    only leak i have is on top of the lockout so probably a O ring.
    question mainly was if i dont remove the seal+foam does it matter if i then spray degreaser/isopropyl alcohol inside lowers to remove?
    Former Bike Wrench
    Don't use degreaser, just alcohol. Just leave the seal and foam ring in place.
    Mar 2011
    k cheers that all i really needed to hear.
    does it matter if i use some oil on the foam rings to lube them up as well as oil used to fill the lowers up?
