Reusable link in my chain
Printable View
  • 08-27-2015
    xlash
    Hi guys, I have a KMX C 10 speed chain that has a reusable link. What does that mean? Where is this reusable link? How would I be able to use think link with a broken link?
    yes I am a complete n00b when it comes to chains. Thanks.
  • 08-27-2015
    Shakester
    You're probably referring to the quick link system or missing link. Your chain should come with a set of these..
    https://www.youtube.com/watch?v=oFq11_t1smk
  • 08-27-2015
    eb1888
  • 08-27-2015
    Harold
    Buy a few extra KMC missing links for emergency splicing of broken chains. Keep in mind, SRAM offers a quick link, which is a similar concept (and they are cheaper)...but they are NOT reusable. You can also use these for emergency repairs.
    If I buy a SRAM chain, I keep SRAM's quick links for emergency repair. I install a KMC missing link (reusable one) so that I can remove the chain for cleaning and continue to use the same missing link. I tend to accumulate SRAM links because I only use them for repairs, so I have a bunch.
  • 08-27-2015
    xlash
    Thanks guys. Now if my chain does break at some point how do I use this missing link to fix it?
  • 08-27-2015
    xlash
    Ok I get that. But what's the point of the missing link that's already on my chain?
  • 08-27-2015
    life behind bars
    The video posted above does a pretty good job of explaining its use.
  • 08-27-2015
    xlash
    I've seen the video and I know that it's easy to take the chain on and off. But let's say I have a broken link a few links down then how is this supposed ro help me?
    Or do I need another missing link to fix it and the one that comes with the chain is just to take the chain on and off.
  • 08-27-2015
    life behind bars
    Yes, you use another link to reconnect the chain, carry a couple of spares with you on your rides. I buy them 10 at a time, frequently come across other riders in need of one.
  • 08-27-2015
    xlash
    Thanks you so much. And since I have a KMC chain I suppose I can use a Shimano link as they are compatible. Am I right?
  • 08-27-2015
    life behind bars
    I use KMC links, have zero experience with Shimano. It would be prudent to test it out before venturing into the wild.
  • 08-27-2015
    Shakester
    You'd probably need a chain tool to carry with you on the trail. If you do break a chain, its a quick and easy way to get you back riding. But know that you'll be shortening your chain and will have trouble shifting to your biggest cog but at least you're not stranded.
  • 08-27-2015
    rangeriderdave
    Shimano doesn't make/use a removable link,they use a pin that you install with a chain breaker .You can use a KMC link on a Shimano chain. KMC or somebody else makes the Shimano chains.
  • 08-28-2015
    TiGeo
    The KMC link ("missing link") is a nice one b/c you can re-use it. Just examine the chain carefully and look for the one link that has elongated holes where the pins go. You can break it at this point with a special tool for the purpose or may be able to do this by pushing it together with your hands (can be hard to do). I always carry a chain tool and extra missing link so I can repair a chain break...you would use the tool to remove the broken link and then put it back together with the missing link...its really just to make things easier..you can also use a chain tool to push in/out pins to patch chains back together.
