Presta Valve- Mtbr.com
Results 1 to 9 of 9
Thread: Presta Valve
    Presta Valve
    So I broke off the tip of my presta valve and wondered if I need to replace the whole tube now? to answer the questions I was topping off the tire with my hand pump for a morning ride and the bike fell over snapping off the valve...
    my body breaks the falls
    Reputation: twindaddy's Avatar
    Replace it instead of what? Repair? Eventually you'll need to get air into the tube. I can't imagine how repairing that would be any easier or cheaper than a new tube. Sometimes your time becomes more valuable to you than your money - especially with something as inexpensive as a tube
    I was wondering if there is a replacement tip that screws down into the valve that I can buy rather than pulling the whole tube...
    New tube. Only if it had a removable valve (like the mavic wheels) but that's in a tubeless wheel not a tube.
    Quote Originally Posted by twindaddy
    hes talking about replacing it like a schrader valve inside - screw the old one out and screw a new one in.
    Jul 2003
    Nope.....
    can't repair prestas. You'll need a new tube.
    Good Dirt
    Masher
    Changing tubes is one of those no-brainer things that need to be done so often it's second nature.
    Here's an idea - time yourself! The faster you learn to do it the less you will hold up the group.
    New Presta tubes can run as cheap as 2.50-3.00. Don't waste your time noodling with fixing a valve.
    He is totally right. A tube costs about 5 bucks.I have never heard of repairing a valve and if you did it would cost just as much.
    You also need to put a value on your time. Is it really worth the trouble?
