Preload knobs- Mtbr.com
Results 1 to 6 of 6
Thread: Preload knobs
    Preload knobs
    can i take the preload adjuster knobs off my rst launch forks or will all the oil and stuff inside come out???
    ________________________________
    The best way to make your dreams come true is to wake up.
    Um...why are you taking the preload knob off?
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    You can take off the caps the preload adjusters sit on off, but the internals will come out. That's what they are for. Also, why are you taking the preload knobs off?
    yer, i wasnt sure if i loosen them off too far whether they screw off or not
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by StonedEagle99
    You will not take the knob off by turning the preload adjusting knobs. You will only get the internals to fall out if you remove the top cap or maybe if you break the adjuster clean off and damage the top cap. Adjusting the preload knobs will not cause any damage as long as you aren't forcing them to turn when they don't want to turn.
    What ^ he said.
