Newbie installing new pedals (Kona Wah Wah)- Mtbr.com
Results 1 to 7 of 7
    Nov 2007
    New question here. Newbie installing new pedals (Kona Wah Wah)
    Hey y'all -
    I just picked up some new Kona Wah Wah pedals for a 1999 Marin Nail Trail I took out of the garage -
    QUESTION: The pedal arms are round (?) - and not octagonal like the ones I'm used to - how do I install these even if I get a pedal wrench? Am I missing something here? While I'm at it they don't 'spin' it appears like the stock ones do on the bike - is this normal?
    Thanks !
    I'm not familiar with those pedals, but many pedals can be installed with a hex wrench through the hole in the crank arm.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    they might be like my mallets and have a hex key insert at the end of the threads???
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    pedal pusher
    Reputation: f3rg's Avatar
    Yeah, get an Allen wrench and look at the pedals from behind the crank arm. You'll see where to insert the wrench. Whatever you do, don't get a wrench or vice grip and grab onto that spindle.
    Nov 2007
    Guys - This is great - totally solved my problem ( ! ) -
    One more question - what type of lube should I use - basic lube?
    Thanks again -
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Teflon based grease works well.
    SuperInstigator
    Reputation: tibug's Avatar
    I just use the 3$ 16 oz. container of "Multi-Purpose EP Wheel Bearing And Chassis Grease" that I get from the local Napa auto parts store. It's what we use at the shop, and it works great. I think automotive ball bearing grease is your best bet.
    I'm probably not the best authority on this though; my experience with different greases is very limited. snaky69 probably [definitely] knows what he's talking about more than I do...
    Tim
    I wish I didn't know now what I didn't know then.
