Results 1 to 2 of 2
    new riser bar question
    got a new set of 2.5 rise handlebars. I have already got a new set of grips for them. so here is my question, do i have to remove the grips each time i wanna switch out my bars? i couldnt tell if i would be able to remove the controls without having to slide them off the bars by way of the grip?
    Enthusiast
    Reputation: JonathanGennick's Avatar
    Typically you will must remove the grips when switching bars, yes. If you swap bars a lot, look into what are called "lock-on" grips. Those are great. I run them on all my bikes now, and switching bars around is much less painful than it used to be.
