Results 1 to 15 of 15
    new gary fisher HI FI
    i just bought a2007 gary fisher hi fi this is my first fs bike any suggestions on set up . i am 5' 9" an 180 any help would be great thanks
    Oct 2007
    Hey John, welcome. I'm afraid I don't quite catch what you mean by "setting up." Is the bike disassembled?
    Reputation: srey's Avatar
    You will need to set the sag for your weight. If you have an air shock and fork you will need a special pump to adjust it. If it is a coil fork you will need to buy a new spring for it (but only if it doesn't sag right). At your weight you will probably be ok with the spring that is probably in your fork(I am pretty sure that it is probably a coil fork). Ask more specific questions and we can help you out more.
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Congrats on the new bike....like the others have said elaborate a little more so we can provide better feedback.
    There is not much choice between rotten apples.
    Oct 2007
    I dunno, the new Hifi's come with either Reba's or Fox's so he may not have a coil fork.
    Feb 2005
    Search Google for bike fitting info
    You're going to have to do a lot of on-line searching and reading, but you'll find all the info you need. Then after that if you have any questions we're all here to answer. What I really would recommend is if you have the cash having a professional fitting or if you bought if from a LBS they should have set you up correctly with the seat position, seat angle, seat post height (for correct leg extension), then stem and spacer adjustments. The LBS should have done all this for free before you even took the bike out the door.
    If you're not falling, then you're not riding fast enough!
    Ibex Asta Pro SE & Giant XTC-2
    congrats on the purchase, gary fisher FTW!
    try posting this on the gary fisher forum too you'll probably find your answers there...
    Big Wheeler
    Reputation: Encierros's Avatar
    congrats John!
    like the others said...
    If you have Fox suspension check out their website. There's an extensive downloadable manual / maintenance guide for all their products on the tech center.
    should have mine this weekend (fingers crossed)
    Quote Originally Posted by EclipseRoadie
    no its all together just wondeering about suspension the users manual isnt very clear
    it comes with a manitou relic front fork and a fox float rp3 rear
    Quote Originally Posted by baraant
    they showed me a few things but not any thing u mention
    Quote Originally Posted by Encierros
    congrats John!
    i went to there sight .icould find my shock(float rp3) but when i click on the manual it gives me a list of 3 other ones that arent mine .maybe i did something wrong i will check again
    thanks for the help everybody very much appreciated
    Big Wheeler
    Quote Originally Posted by john k m
    here's a direct link to the site i was referring to:
    http://www.foxracingshox.com/fox_tech_center/index.htm
    http://www.foxracingshox.com/fox_tec...008_om_eng.htm
    on the left there's a menu that answered a lot of my questions
    thanks that helps . the first link has just what i was looking for
