Muddy Weekend, have some questions- Mtbr.com
Results 1 to 12 of 12
    I had my first two races a couple of weekends ago (didnt get last in either ) that left my bike muddy and wet all weekend and Im having a bit of trouble. Theres a squeak coming from somewhere, chain or derailleur Im guessing, but Ive lubed both and cant seem to get rid of it (any ideas?) Something else that I just noticed is that my cassestte no longer makes the "click" that it used to though if I listen very closely I can hear it a little. Is this a problem? I think thats it for now. Ill let you guys know if anything else comes up. Thanks
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    Disassemble, clean, lube and reassemble all the drivetrain components including the pedals.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Well, if you've properly lubed your chain then it's unlikely to be the culprit. Jockey pulleys, pedal seals, and BB seals would be my next guess. Just be careful lubing those, use a very small amount as it goes a long way.
    I'm not sure what you mean by the cassette was clicking, the cassette has no moving parts and should be making a sound. Do you mean the shifter perhaps?
    Sorry by the cassette I meant when I am coasting or walking the bike, not when I am pedaling
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by Sean831 View Post
    Ah, that's the freewheel/freehub body. I wouldn't be concerned if it's quieter than normal. Some hubs get quieter when they get rode some get louder, if it starts failing to engage when you pedal then you might have a problem.
    Quote Originally Posted by zebrahum View Post
    thanks. i guess i didnt really think that one through too much, good to know though. but cool as long as its fine might as well keep riding
    Hey guys, Im still having problems with a squeak thats driving me nuts. I lubed my jockey pulleys and chain fairly well using Finish Line Wax Lubricant for dirty and dry conditions. It doesnt seem to be my bottom bracket and its not my pedals. The sound comes mostly from the back and seems to be either the pulleys or chain having to bend more to go around the small pulleys, but I cant figure out what to do.
    Also, my BB has decided to start acting up on me and under load makes a popping sound. Any ideas on this?
    Thanks,
    Sean
    Picture Unrelated
    Jun 2005
    Thanks,
    Sean
    Try a different lube, I don't care for wax lubes.
    If your BB is popping there's probably something loose. Crank arms, pedal spindles, BB, check them all.
    Hi.
    Reputation: jtmartino's Avatar
    Your squeak is likely coming from your rear derailleur pulleys. Remove the pulleys completely, clean them, and re-lube with grease or heavy oil. This means unscrewing the pulley from the derailleur cage and taking it off the bike, taking off the bearing shields, and cleaning it all out.
    How did you clean your bike after it got muddy? A lot of people spray high pressure water at sensitive areas, which is the fastest way to develop a squeak or rusted bearings.
    seat post this is where i almost always find to be the source of my squeaks, clean and regrease the post, all the interfaces on the clamping mechanism and the bolts
    My seatpost also makes noise too. Any suggestions for a grease for the post and pulleys? Ill also ask around campus to see if anyone has any tools to tweak the bottom bracket. Thanks guys
    Hi.
    Regular bike grease like Park Tool should be fine. Automotive grease may work in a pinch.
    Make sure you take your seatpost binder/collar off the frame, clean it out, and put it back together. Some grease on the bolt threads would help. I also lube and check the seatpost clamp where it meets the saddle, and where the saddle rails meet the bottom of the seat.
  1. Fenders for a muddy weekend
    By Clones123 in forum Where are the Best Deals?
    Last Post: 04-29-2011, 07:35 AM
  2. Replies: 8
    Last Post: 05-26-2010, 03:27 PM
  3. Alternative to the muddy trails this weekend
    By riderx in forum Virginia, WV, Maryland, DC, Delaware
    Last Post: 03-06-2009, 09:13 AM
  4. Muddy Burnner-I mean very muddy...
    By dtrek4500 in forum Turner
    Last Post: 02-21-2006, 09:07 AM
  5. Will Killington be muddy this weekend??
    By soulfly_NYC in forum Vermont, New Hampshire, Maine
    Last Post: 09-01-2005, 05:30 AM
