MTB fork - rare / low cost maintenance or very long maintenance period.- Mtbr.com
Results 1 to 11 of 11
    Feb 2014
    Hi Guys,
    Please I need help , I wanted buying a fork for my bike (all mountain)
    and I search for a very reliable fork that not need maintenance or the maintenance is very simple. I don't care about features of fork or the comfort - how it works, the weight can be medium. the budget can be around to 500 euro.
    so:
    1. the first criteria is maintenance and the security( I run fast on the mountain).
    2. then the weight
    3. the how it works
    4. features
    marzocchi vs fox vs rockshox ?
    thanks for suggestion
    marius
    Dec 2010
    You're going to need to give a lot more info before we can help you.
    So:
    1.What bike will it be for?
    2.What wheel size?
    3.How much travel?
    4.Rim or disc brakes?
    5.Tapered or straight steerer?
    Feb 2014
    1.bike will be for up and down from montain
    2. well is 26
    3. one per week
    4. disk brake
    5. I did't understood :-)
    Dec 2010
    Quote Originally Posted by pred View Post
    2. well is 26
    3. one per week
    4. disk brake
    You didn't understood 1, 3, or 5.
    1. What specific bike will it be for? Make, model, year? That will help us narrow down the options for you.
    3. If you can answer #1, we can answer #3 for you.
    5. If you can answer #1, we can answer #5 for you.
    Travel is how much the fork compresses.The steerer tube is either tapered or not .
    Feb 2014
    1. ram bike, 2007 http://ram-bikes.com/2011_archive/en...gue_en_web.pdf
    the size bike is 16 or 18 inch
    Fat-tired Roadie
    Nov 2007
    If reliability and feature set are your first two criteria, you can nail those with a rigid fork.
    I think you need to think about what features and level of performance you don't want to give up.
    People do report less effort maintaining coil spring forks. Get one with a rebound damper only (I'm projecting my minimum feature set on you) and there are fewer bits to break.
    Another thing is if you ride ,then you need to maintain the bike ,all forks have a schedule of changing oil . You could look them up. Like Andrew said no maintaining a rigid fork.
    Feb 2014
    thanks for info but I prefer no rigid fork
    since 4/10/2009
    Reputation: Harold's Avatar
    Agreed. Rigid fork has least maintenance.
    Elastomer forks are "low maintenance" but ride quality sucks. Just squirt grease into them, for the most part...until the elastomer dies. By then, replacements are probably not made anymore and you can toss it in the trash.
    Coil forks probably next.
    Then a basic air fork.
    Start adding compression damping to anything, and you increase the complexity and maintenance.
    B A N N E D
    Which bike model in the catalogue ?
    Do you have a 2007 model or a 2011 model ?
    A 2007 bike might have different specs to a 2011 bike.
  1. Replies: 2
    Last Post: 11-26-2013, 07:00 AM
  2. Fork Maintenance
    By TwoNinerNY in forum 29er Bikes
    Last Post: 07-28-2013, 05:01 PM
  3. Excavator yearly maintenance cost
    By mtbty in forum Trail Building and Advocacy
    Last Post: 04-20-2013, 06:12 AM
  4. Replies: 38
    Last Post: 10-09-2011, 06:29 PM
  5. Bike maintenance, how to make it more cost....
    By ManianMTB in forum General Discussion
    Last Post: 08-17-2011, 11:40 PM
