MTB clipless shoes- Mtbr.com
    Dec 2010
    MTB clipless shoes
    I've been looking for a while to convert my bike to a clipless petal set up, and I finally decided to go along with it. The only problem is I wear about a size 12 wide shoe and haven't had any luck on finding one that was comfortable or felt good enough to wear on a long ride. Any suggestions where I would be able to find a good pair or any suggestions to what brands maybe good? Thanks.
    meow meow
    Reputation: b-kul's Avatar
    pretty sure most brands make a wide size but they may have to be a special order for your lobs.
    Oct 2010
    The problem with Nimitz-class feet (11 4E here) is you're usually out of luck with cheap shoes. I just picked up some Specialized Pro shoes. had to go with Pro as the Comp and Expert don't come in wider widths.
    So far so good, although I would like the shoes to have a bit more volume at the top. Sidi also makes some of their shoes in "Mega" widths.
    Check out the Sette Enduro at Pricepoint
