mid ring questions- Mtbr.com
Results 1 to 2 of 2
    zul
    zul is offline
    Will Guide for Beer
    Reputation: zul's Avatar
    mid ring questions
    I am running a 4-bolt 104mm BCD 2-ring setup w/ bash guard. The 'middle' (or top ring) is worn out and skipping. There are several options around $14 at Jenson. Can I select any of these or will I need a different set of bolts based upon the new ring? Any suggestions? Price sensitive.
    What is the difference with those that have 'pins'? What's the purpose of the pin?
    If lovin you is wrong, I don't wanna be right
    Pins are to assist shifting, and no pins are mainly for Single Speed. New bolts are 99% not required to replace a wornout ring.
    You Can't Triple Stamp A Double Stamp!
