Mechanical disc brake noise (Tektro Novela)- Mtbr.com
Results 1 to 7 of 7
    Feb 2014
    My rear disc brake has been making a noise when half-braking. It is not a rubbing noise it is like a grinding noise (kind of like the noise a car makes when it need new pads). I checked the brake pads and they are over 3mm thick, cleaned the pads and rotor with isopropyl alcohol and adjusted the brakes. The noise is still there, I notices the rear pads and rotor have circular lines all over them, while the front brake pads and rotor don't. Do any of you know what the problem might be? Thanks.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    if they are silent when not braking, i say run it. probably needs some real world use is all
    grinding can be worn pads (not your situation)
    or pads and rotor not mated
    closeup pictures of offending assembly can help diagnose
    Reputation: hankscorpio's Avatar
    Jun 2012
    I've been on these for 2 years now. you can spend a bunch of time chasing it down, get it adjusted and cleaned and stop it, then it will be back for some other reason. These brakes are loud and not so great especially if you do any descending. I'm looking to fit some deores this year
    Fat-tired Roadie
    Nov 2007
    It's grit.
    Get over it. Even if you chase it down, next time you ride on a wet enough day to get more dirt into your caliper, it'll be back.
    Jan 2009
    take your pads out and lightly sand them down under running water. dry them off and re-install. be careful not to touch the braking surface. a little noise is common and acceptable to me, so don't sweat it.
    Feb 2014
    Quote Originally Posted by mack_turtle View Post
    Thank you, what grit would you recommend? when you say not to touch the braking surface, you mean of the rotor right?
    Jan 2009
    I mean on the pad and the rotor. don't touch them.
    medium grit works, or use whatever you have. you don't want to polish the surface with a fine grain, but you don't want to wear it right off with a coarse grain.
  1. Tektro Novela
    By SIKOSYC in forum Brake Time
    Last Post: 11-28-2015, 08:44 AM
  2. Tektro Novela Mechanical Disc Brakes
    By etboost in forum Beginner's Corner
    Last Post: 10-31-2013, 08:08 PM
  3. Replies: 2
    Last Post: 04-11-2013, 05:51 AM
  4. Replies: 9
    Last Post: 06-27-2012, 01:42 AM
  5. Help adjusting Tektro Novela Mechanical Disc Brakes
    By getagrip in forum Beginner's Corner
    Last Post: 07-10-2011, 07:46 PM
