loose headset- Mtbr.com
Results 1 to 12 of 12
Thread: loose headset
    Feb 2006
    loose headset
    I am trying to put a surly 29er fork on my 26 bike and whatever I do the fork seems loose. I have tried many things like putting more spacers, taking the wheel off, tighting the bolt on the starnut (before tightening the stem of course) but it seems impossible to make it tight. Is it possible the problem to be because of the longer fork? Or it could be a headset problem ( the headset is m-part brand and almost new)
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    if you're doing things right, then the longer fork will not cause the headset to be loose. You need a few mills of clearance to the top cap to adjust it properly. Loosen the stem up really far and try to adjust it again. If you can't tighten it enough, you need more spacers.
    Is there a crown race on the new fork?
    MUD
    My weiner is 10.5".....Oh wait...I'm holding this ruler backward.
    Feb 2006
    Quote Originally Posted by A from Il
    what is a crown race??
    Quote Originally Posted by Markleo
    Compare the area where the steer tube meets the crown and the old fork and the new one. There is a race pressed onto the steer tube all the way down for the lower headset bearing to ride on. If the surly fork is brand new there probably isnt a race on it. They may be your problem.
    MUD
    Feb 2006
    I see, you mean a star nut. I installed one. I actually replaced the headset and there is again the noise, but after all I think it is not the headset's problem. When the wheel is off there isn't that play.
    Reputation: Brujo's Avatar
    not the star nut he means the crown race for the lower headset bearing
    pic from park tool page
    2009 Giant Yukon FX
    Feb 2006
    I see, yes there is a crown race on the fork from the new headset installed
    Reputation: Dremer03's Avatar
    Not enough spacers above the steerer tube?
    Big Foot Blue KHS XC704r
    Picture Unrelated
    Jun 2005
    Ok, then we need some pictures. Something is wrong and unless you can hold it up to the internet so we can fix it for you, pictures or go to your shop.
    Rabid Lana fan
    Won't it whack out the geometry to use a 29er fork on a 26" frame?
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by net wurker
    Yep, it'll ride awful. But the headset should still work (until the bearings blow out).
