Help Choosing a Shimano Rear Derailleur- Mtbr.com
Results 1 to 10 of 10
    Does this look infected??
    Reputation: robd928's Avatar
    Hi I'm building up a Bandersnatch and am confused on what rear derailleur to order.
    I'm using a 3x9 crankset SLX 44/32/22, the cassette is 11-32 and the chain stays on the frame are 454.5mm
    I want to get the XT or the XTR but not sure which one. I'm a bit confused on the cage length and Rapid rise.
    Can someone put me in the right direction please??
    long cage, non rapid rise.
    Quote Originally Posted by rkj__
    "It's amazing how people can make bicycle riding seem so complicated on the internet."
    Enthusiast
    Reputation: JonathanGennick's Avatar
    I believe the OP will need a long cage. Here's what I find in the specs on Shimano's website:
    RD-M772-GS (medium cage), 34 tooth capacity
    RD-M772-SGS (long cage), 45 tooth capacity
    The OP needs 43 teeth: (44-22) + (32-11).
    I would further recommend a Shadow derailleur. I like their stronger spring and straight-through cable routing.
    FWIW, Jenson has great pricing on OEM SLX Shadow models. Those are worth a look.
    Enthusiast
    Ok. Jenson seems to be out of those SLX models. But here's a Shadow XT for only $70:
    http://jensonusa.com/store/product/R...ar+Der+Oe.aspx
    And for major bling, here's the XTR version for $150:
    http://jensonusa.com/store/product/R...illeur+Oe.aspx
    Either should work.
    Ordered that one from Jenson......Thanks for the help.
    Rob
    KC Weekend Warrior
    Reputation: the.rebot's Avatar
    Jun 2010
    Can someone offer a short explanation of the differences and advantages/disadvantages of rapid vs non-rapid rise? I am also in the market for a rear derailleur, don't think I'll go higher than LX unless there is a super deal.
    Reputation: s0ckeyeus's Avatar
    Basically Rapid Rise shifts in the opposite direction as regular derailleurs. With no cable tension, the RR derailleur rests over the big cog instead of the small cog. The shifters will also shift opposite of regular derailleurs.
    RR seems more intuitive to me on the trails. I use the thumb to shift on the downhills and the forefinger to shift on the uphills. My shifter allows multiple shifts with one push of the thumb lever. I find I'm more likely to need to shift quickly to a more difficult gear, rather than an easier gear.
    (Check eBay for new derailleurs and compare the prices to online bike vendors, like JensonUSA. Sometimes you can get great deals on brand new stuff.)
    KC Weekend Warrior
    Jun 2010
    Quote Originally Posted by s0ckeyeus
    Thanks.
    one less car
    Reputation: B@dKarma's Avatar
    Quote Originally Posted by Mount Dora Cycles
    what's wrong with rapid rise? I have the XTR short cage version and have had no probs with it, other than a cable break. woulda been damn inconvenient to not have been stuck on the larger cog.
    if anyone's wondering what to get, go RR. one day, and you will, you'll break a cable, quite likely on an up hill, and wish you had a RR
    nothing in life is real, so if anything goes wrong, blame the dead guy
    Nov 2013
    answering to mark the post
