Hard tail and Full Suspension........Soft tail?- Mtbr.com
Results 1 to 5 of 5
    So I get the HT and the FS, but soft tail? Is it just for people that can't decide and want to split the difference? Are they easy to find or very niche? Is there a type of riding they accel at? To be a soft tail does it need to have a spring and damper, just a spring, just a damper? Is it just a hard tail with a ton of flex or is there an actual suspension in the rear? Is there an accepted design for a standard soft tail or is it a very loose definition?
    I know a lot of questions, but...I guess I just like to learn. Thanks guys!
    2015 Trek Domane 4.5 Disc
    2015 Trek Fuel EX 8
    2015 Gravity Bullseye Monster LTD
    2012 Trek 4900
    1993 Giant Rincon
    Soft Tail usually means...
    A bike where the rear swingarm flexes without an axle....Usually found on a Ti frame.
    They often have a shock and sometimes linkages...
    Reputation: theMeat's Avatar
    fully rigid or rigid = no suspension
    HT or hard tail = rigid rear, suspension front
    FS or full suspension = suspension front and rear
    Soft tail just means it has some sorta suspension to make the rear softer over bumps. So when it comes to bikes if it has rear suspension it's pretty safe to say it is a FS. At least that's what I think.
    Round and round we go
    So is a soft tail something that people just kind of ignore? Does it have it's place? It seems like it might be a good compromise between the two extremes. Do you end up a best of both worlds or worst of both worlds?
    2015 Trek Fuel EX 8
    2012 Trek 4900
    1993 Giant Rincon
    Quote Originally Posted by kwikshift View Post
    Moots FEATURES
    I think they have up to 4 inch rear travel on some soft tails....
    They have their place.
