Results 1 to 2 of 2
    Handlebar Lenght
    Has anybody cut their handlebars? is there a way to figure out what the lenght should be?
    Reputation: Kaba Klaus's Avatar
    Yep. I cut handlebars. Best tool is a pipe cutter. You get that at Ace, Lowes or HD. Saw will do the trick, too.
    As for the desired width... well, that is a matter of personal choice. I'd recommend to cut a little, give it a try and cut some more if it feels still too wide. Another trick is to use lock-on grops and simply move everything more to the cener for a test. Never mind the end of the bar sticking out.
    In any case I would not recommend to cut the bar shorter than your comfortable push-up spread. Do a push-up and measure the distance between the outsides of your hands. It is a clue. Bar can be wider (more control) but should not be shorter (you'll start to constrict your breathing).
