Front tire recomendations?- Mtbr.com
Results 1 to 15 of 15
    Jun 2010
    Hi, I have giant xtc0 with continental 2.1 speed king tyres. My back tire is almost gone about ~30% left. So I want to put my front tire on the rear wheel and buy a new tire for the front. I believe the main problem is that on corners I don't get a lot of tracktion going on and I'm always afraid that my front tire would just skid.
    Mainly I ride dry hard ground with some random loose bits, easy up hills and downhills. What impact does the width of the tire has for cornering?
    What would you suggest for under 25 pounds?
    T.W.O
    Reputation: pfox90's Avatar
    Aug 2010
    If your not running tubeless, 25 lbs is really low. The width of the tire does just exactly what you would imagine it would do.. gives you a large traction surface. 2.35 front and 2.1/2.2 combo in the back is good for just all around trail riding. I personally have a Panaracer Rampage 2.35 on my bikes and it is great for cornering. Doesn't weigh that much either... only 700g
    ------__o
    ----_`\<,_
    ---(_)/ (_)
    Jun 2010
    I ment the budget of 25 pounds..
    Sorry for that
    Reputation: jpeters's Avatar
    You have so many options but the speed kings make a awful rear as far as lasting. I personally like the speed kings alot but they don't last. The Schwalbe Rocket Ron, Continental race king, Schwalbe Racing Ralph. are all good. Take a look at bikeradar.com and look up tire reviews. They give great reviews on lots of tires.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    One thing about front tyre traction is: you need to have some weight on the tyre.
    Sometimes people put all their weight on the rear because they fear that weight on the front will make the front tyre wash out. More commonly, the opposite is true.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    Jun 2010
    Hmmm I haven't thought about that. Normally my mass is in the center of the bike. And another quicky 2.4 in front isn't an overkill?
    local trails rider
    Aug 2005
    I run 2.4" front and rear...
    2.1" and 2.4" would be an uncommonly big difference but I am not sure it would cause problems.
    BTW Tyre companies measure their tires in different ways. I know for a fact that a 2.4" Continental Mountain King is not the same size as a 2.4" Schwalbe.Fat Albert.
    Aug 2010
    2011 transition 250
    2009 DB scapegoat
    T.W.O
    Aug 2010
    Quote Originally Posted by Twisted1 View Post
    900g tire is pretty heavy
    ------__o
    ----_`\<,_
    ---(_)/ (_)
    T.W.O.
    Reputation: mimi1885's Avatar
    Quote Originally Posted by pfox90 View Post
    It's a solid advice, I'd take his point.
    If you want more traction tires like Rampage, Nevegal, Excavator are good choices.
    +1 on the Nevegals
    Not sure if its gonna be under 25 pounds... Maxxis Minion DHF 2.35 or 2.5 is gonna be your best bet on a front tire. They do run narrow, 2.35 is about the same as a 2.1 and 2.5 is closer to a 2.3-2.4. These tires usually out perform others...read up on bikeradar and other sites and you'll see. Around 700g for the single ply.
    Fat-tired Roadie
    Nov 2007
    I really like the Panaracer Dart Classic. It's relatively inexpensive, even in the folding version, which is the one I like, and I love the way it corners. It also rolls fast. I think it's a little easier to lock it up under braking than something with a less elongated tread, but with good technique, it's more than adequate for that too. It should be a good match for a racey 2.1" rear tire.
    Bicyclochondriac.
    Quote Originally Posted by zmogedra View Post
    I assume you want something under 800 grams? If so, there are a number of good option weighing in between 700-800 grams.
    I could list some options, but you will do better to go look around the Wheels and Tires board, and find loads of opinions.
    To answer your question about tire width, I do think that larger tires have an advantage in the front. The biggest thing is being able to run lower pressure which helps in grip and offers some extra small bump compliance (which also adds to grip). Additionally, I find wider tires generally are more stable in the rough, getting deflected less easily (lower pressure adds to this strength).
  1. tire recomendations?
    By johnism in forum 29er Bikes
    Last Post: 01-05-2010, 07:54 PM
  2. Tire recomendations
    By millman in forum Beginner's Corner
    Last Post: 06-15-2009, 08:29 PM
  3. NM tire recomendations
    By nmyeti in forum New Mexico
    Last Post: 07-22-2008, 07:26 PM
  4. Tire Recomendations
    By bdogfish in forum Singlespeed
    Last Post: 03-06-2008, 10:41 AM
  5. recomendations for big front UST tire
    By Maida7 in forum Wheels and Tires
    Last Post: 05-06-2006, 11:07 PM
