Fork Preload problems. Please Help!- Mtbr.com
    Jan 2015
    Caution;  Merge;  Workers Ahead! Fork Preload problems. Please Help!
    OK, so I just got a new bike. It is the Nashbar at29. It came with a low end suspension fork, the suntout xct 28. It has a speed lockout on the right and the preload on the left. This is not an air suspension, it is a spring suspension Anyways, I wanted to know how many revolutions the preload might take and where is the limit? Are you supposed to hear clicks? I think that I have the preload all the way to the left, the weakest point, but when I sit on the bike, it's very stiff. There is no sag at all. I wanted to know if I should force the preload more to the - sign or of that is the limit. Thanks!
    B A N N E D
    Ask Nick, he works for Suntour: http://forums.mtbr.com/member.php?u=572346
    Forcing the preload will probably break it.
    Lone Wolf
    Reputation: Osco's Avatar
    Apr 2013
    SR Suntour North America
    The Raidon is a $350 fork, this upgrade deal lets you play for $189
    It will transform your bike :P
    “I seek only the Flow”,
    Climbing Is Supposed To Be Hard,
    Shut Up Legs :P
    Is there a change when you use the lockout? If not, you could have a spring weight inside that is too firm for your body weight. Or something could be messed up with the lockout system.
  1. preload on fork - purpose
    By sanjayc in forum Beginner's Corner
    Last Post: 10-25-2012, 06:13 PM
  2. Fork lockout(right side), preload(left side). What's preload?
    By Downhill83 in forum Beginner's Corner
    Last Post: 06-16-2012, 04:48 PM
  3. Coil fork , spring preload ?
    By keen in forum Shocks and Suspension
    Last Post: 08-02-2011, 04:32 PM
  4. Fork preload question
    By nrg2go in forum All Mountain
    Last Post: 03-16-2011, 12:47 PM
