Results 1 to 3 of 3
    Nov 2008
    Fixing Brake Rub?
    I got a new Trek with disc brakes which I'm completely unfamiliar with. with the bike upside down and the front wheel hub loose and unlocked the front wheel spins with out a problem. Once I lock the hub I hear a slight rub on its rotation and the wheel slows down quickly.
    What should I look for to adjust? Where is a good resource to read about working on disc brakes?
    Here are a few specs:
    Brakeset - Avid Juicy 5 Hydraulic w/185mm Rotor front/Avid Juicy 5 Hydraulic w/160mm Rotor rear brakes, Avid Juicy 5 levers
    Shift Levers - Shimano LX Rapid Fire
    Front Derailleur - Shimano LX
    thank you.
    Nov 2008
    try here:
    vorb
    Nov 2008
    Quote Originally Posted by bwana devil
    try here:
    vorb
    that worked. thanks.
