Fender modification to fix full fender to MTB with suspension- Mtbr.com
Results 1 to 3 of 3
    Jan 2011
    Hi,
    I am trying to fix a SKS P65 chromoplastic fender to my Trek 4500 D. The front part is tricky with suspension not having eyelets for attaching the stay.
    I took one of the v stays and bent the upper rod in center so that it curves upward and I can angle the v stay so that it attaches on suspension fork above the disk brake.
    I plan to put inner rubber tube patch on suspension tube and run a cable tie through the safety release of the stay and attach it to the suspension .
    Is this a good idea or could there be any problems with it ?
    A lot of work for what shouldbe an easy fix . SKS makes a fender mount for suspension forks, the mount goes into the bottom of the fork with a bracket ,the bracket attaches to the fender. It has a quick release so you can install and remove in seconds.
    since 4/10/2009
    Reputation: Harold's Avatar
    Suspension precludes the use of a full fender. Period. You have to use a fender made to be used on a suspension fork.
    It was enough work for me to mod a full fender for use on my road bike with disc brakes.
  1. Fender suggestions for a full sus MTB
    By RCook in forum Commuting
    Last Post: 02-05-2010, 12:56 PM
  2. Which 29er SS's have full fender mounts?
    By Western in forum 29er Bikes
    Last Post: 12-24-2008, 06:19 AM
  3. Replies: 0
    Last Post: 03-10-2008, 12:13 AM
  4. Replies: 0
    Last Post: 03-09-2008, 11:53 PM
  5. Full front fender on carbon fork? How?
    By Fastskiguy in forum 29er Bikes
    Last Post: 02-06-2008, 08:17 PM
