do i need a different chain tool?- Mtbr.com
Results 1 to 13 of 13
    I bought a chain tool last night and popped off one of my chains easily enough, but my other bike's chain doesn't want to budge. Do I need another tool?
    bi-winning
    Reputation: rkj__'s Avatar
    You have not provided enough information to get answers to this question.
    What chain tool do you have?
    What chains do you have?
    Most likely, the problem is not the tool, but I can't say for sure without more information.
    I don't know if I can answer the second question, but its just a 5 dollar Bell tool from Walmart.
    bi-winning
    Quote Originally Posted by mmik
    How many gears do each of the bikes have?
    I don't know off the top of my head, but they're different. The one that didn't work has 2 gears in the front, and the one that worked has 3. If you need an exact count I can go figure out what the 2-gear one is.
    bi-winning
    Most 5/6/7/8/9/10 speed chains can all be handled by the same chain tool.
    Some BMX chains are significantly thicker, and require a different tool.
    I suggest you ensure that the chain is sitting nicely in the bottom cradle of the tool (if there are two, the upper cradle is for stiff links) and that the pin is lined up. You may just need to apply more effort.
    Check out this link for info on breaking and installing chains:
    http://www.parktool.com/repair/readhowto.asp?id=25
    I used a wrench on the handle and couldn't get enough leverage to pop it. Is that normal?
    Tool
    Reputation: StageHand's Avatar
    No.
    bi-winning
    The handle on my Park mini chain tool is probably only about 2.5" long, and I have never been unable to break a chain with it.
    the links for the chain fir in the tool fine. is it possible the pins are too skinny?
    Tool
    Not likely.
    maybe they're just really tight then.
    Reputation: sanjuro's Avatar
    Sep 2004
    by perchance, you aren't trying to push the master link?
