Difference between offset and zero offset seatpost- Mtbr.com
    I tried googling but couldn't find an answer: what's the difference between an offset and a zero offset seatpost? Thanks in advance.
    Fat-tired Roadie
    Nov 2007
    Usually about 25mm.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    The terms offset and setback are somewhat interchangeable, but the offset can be achieved a couple different ways, and some seatposts use an offset (or bend) in the post itself and some use an offset clamp design.
    So, you can have a straight post with a zero offset clamp, a straight post with an offset clamp, or a setback post (also known as a 'layback' post) with a zero offset clamp. I can't think of any examples of a setback post with an offset clamp.
    You can achieve the same effect with either a setabck post or an offset clamp. The Thomson layback post yeilds a 16mm offset, and there are many different offset clamp designs that yield about the same net offset or even more up to 35mm of offset.
    1) straight post with a zero offset clamp design
    2) straight post with an offset clamp design
    3) setback (layback) post with a zero offset clamp design
    Attached Thumbnails Attached Thumbnails Difference between offset and zero offset seatpost-thomsonmasterpieceseatpost.jpg
    Difference between offset and zero offset seatpost-bent_saddle-rails_01a.jpg
    Thanks jeffj! That clears it up for me.
  1. Replies: 3
    Last Post: 01-28-2010, 02:10 PM
  2. Seatpost with offset
    By backlaboy in forum Weight Weenies
    Last Post: 05-03-2008, 06:04 PM
  3. Where?! 25.4 offset seatpost
    By Nocturnus in forum General Discussion
    Last Post: 05-06-2007, 11:44 PM
  4. Offset seatpost on an X5?
    By BIke N Gear in forum Ventana
    Last Post: 03-26-2005, 04:08 AM
  5. Replies: 5
    Last Post: 01-13-2005, 10:14 PM
