Results 1 to 5 of 5
    Feb 2006
    derailleur hanger
    Is it safe to remove the der. hanger when we convert to ss? Cause the wheel bolt is screwed on it.Thanks
    Fat-tired Roadie
    Nov 2007
    In general, it's a bad idea.
    How are you going to tension your chain on this build, btw?
    Some companies offer a dummy derailleur hanger that doesn't actually have the derailleur hanger part, but fills the right void on the dropout for things to fit together properly.
    ****** to the dirt
    Reputation: deke505's Avatar
    or you can try and use washers in the place of the hanger but it would be easier just to keep the hanger in there.
    Sep 2012
    I would keep the hanger and chop off the part that you don't need. Similar idea to the dummy hanger.
    Fat-tired Roadie
    Nov 2007
    Chopping off the extra bit sounds good to me. You get the clean look, the quick release skewers sit right, and it's cheap. Win.
