Converting to 1x11 on 2014 Trek X-Caliber 8- Mtbr.com
Results 1 to 14 of 14
    May 2020
    Hello,
    Thinking of converting to a 1x11 on my 2014 Trek X-Caliber 8. I've already changed it to a 1x9, but now want a 1x11. What will I need? Has anyone done it to their 2014 X-Caliber 8? Thanks.
    Attached Thumbnails Attached Thumbnails Converting to 1x11 on 2014 Trek X-Caliber 8-00g0g_ebrb4yshndl_1200x900.jpg
    Aug 2019
    If your hubs are using a shim, you might be good on the wheel side and will just need a new cassette, derailleur, shifter and 11spd chain. If you have to upgrade the wheel, might as well make it worthwhile and jump to 12spd?
    May 2020
    Quote Originally Posted by Trinimon View Post
    I took the cassette off the hub and there are no spacers.
    Aug 2019
    You might be looking for a new rear hub and relace your existing wheel. Probably cost as much to do that as buying a whole new rear wheel on sale.
    Another option is to have someone mill your freehub to fit a 11spd cassette or see if the hub manufacturer offers a replacement 11spd hub.
    May 2020
    That's great! I just ordered my 1x11 components. Now I'll have to get a new rear hub. Can I just replace the free wheel hub and not the whole wheel?
    Aug 2019
    Quote Originally Posted by Lijian View Post
    Only if the current hub manufacturer has a 11spd freehub for it. If not, you'll have to buy a new hub and relace the wheel or mill the current freehub or cassette.
    Turns out that there are (??) manufacturers that make 11spd cassettes that fit on 10spd freehubs.
    May 2020
    I knew I would run into more additional problems with this setup. Thanks.
    Aug 2019
    Turns out Sunrace makes 11spd cassettes that fit on a 10spd hub. I have a couple of the Sunrace MX8 11spd hubs and I did try to fit it on my older Giant 10spd hub but I couldn't fit the lockring after inserting the 11th cog. Strange.
    Maybe I'm smoking crack, but I'm pretty sure the hub is the same for Shimano 9 speed and 11 speed mountain bike hubs. Road hubs are different.
    OP. When you get your parts, try putting it together and see what happens. I bet you'll be fine.
    Sent from my SM-G960U using Tapatalk
    May 2020
    I'll wait until my parts arrive to see what predicament I'll be in. I ordered a SRAM shifter and the other components are SHIMANO so that probably will not work either.
    May 2020
    Quote Originally Posted by d-ron View Post
    Nah, you're right. 6, 7 & 8 speed need a new freehub, 9-11 fits.
    May 2020
    Quote Originally Posted by speedygz View Post
    I'm crossing my fingers on this!
    I think that you might have another problem ,Scam shifters move the cables a different amount of travel than Shimano's ,and the derailleur's are made to match that amount of travel.
    May 2020
    Yes, I was thinking that so a SHIMANO shifter will have to be ordered for this setup.
  1. Looking to go 1x10 or 1x11 on my Trek X-Caliber
    By AWDV8 in forum Beginner's Corner
    Last Post: 07-28-2017, 08:07 AM
  2. Replies: 2
    Last Post: 04-17-2015, 09:50 AM
  3. 2014 Trek Superfly 5 vs 2014 X-caliber 8 vs Airborne Seeker
    By Meekoko in forum Beginner's Corner
    Last Post: 04-04-2015, 04:30 AM
  4. Replies: 12
    Last Post: 06-23-2014, 08:51 PM
  5. Replies: 6
    Last Post: 03-03-2014, 11:44 AM
Members who have read this thread: 26
