Compatiblity issues in upgrade - BB and cranks- Mtbr.com
Results 1 to 7 of 7
    Oct 2017
    Hello
    I want to upgrade my son's bike. He rides a Scott Scale 960, year 2017.
    Among others, it will go from 2x10 to 1x12.
    Now the bike comes with a Shimano BB-MT500-PA / shell 41x89.5mm. That's press-fit. And a 2x10 transmission (36x22front, 11-36 rear).
    I figured out that my combination would be:
    - SRAM NX dub (link to CRC)
    - SARM DUB pressfit MTB Bottom Braket (link to CRC)
    - NX cassette, shifter, derailleur and chain are quite clear.
    Am I correct that these would be compatible with the current setup?
    Are there any (cheaper) alternatives to this upgrade (keeping the 1x12 ambition)?
    Thanks you all!
    Reputation: wickerman1's Avatar
    what size NX cassette? 42? Might have derailleur issues... I would consider getting a GX derailleur
    Oct 2017
    the NX cassette will be 11-50, and the rear derailleur will fit. It's the BB that I'm worried about.
    jcd's best friend
    Reputation: Battery's Avatar
    May 2016
    Are the wheels standard or XD hubs? I just installed my SRAM GX Eagle last night and used a Sunrace 11-50 cassette which is Eagle compatible and fits on a standard hub. If I understand right, the NX Eagle should be standard fit too. If I recall, the GX cassette requires an XD driver.
    From what I learned about DUB, it should fit any bottom bracket. That's what I found on the SRAM website.
    Also, you can check out the SunRace 12 speed setup. It came out earlier this year. They created a shifter, rear mech, and chain to go with their 11-50 cassette. I don't know the exact costs, but I'm sure you can find it online. There is a slight weight penalty with the SunRace cassette, but there aren't a ton of options for a standard hub just yet.
    Trek Émonda | Transition Scout | Transition PBJ | Framed Attack Pro
    Oct 2017
    It's a standard freehub. I hesitate between the 11-50 SunRace CSMZ90 Cassette
    or the SRAM PG-1230 Eagle Cassette 11-50. both work with standard hubs, similarly priced, roughly similar weight.
    But it's not the cassette that I worry about, it's the BB, and the relation between the crankset, the BB and the frame - if the chainring will fall exactly in the middle of the cassette in order to have smooth shifting etc.
    I've read the available info on SRAM site (which I find scanty). I'm betting on the DUB system to be compatible as advertised.
    Quote Originally Posted by Battery View Post
    nx is standard hub GX is XD only
    since 4/10/2009
    Reputation: Harold's Avatar
    your link, strangely enough, doesn't show the product in question. But the way SRAM makes bb's, they only make two standards. BSA threads, or pressfit into a 41mm shell. Since you have a bb shell with those specs, it'll work.
    Chainline is a slightly different question. There are ways to adjust the chainline from however it comes out installed as per directions. Usually involves a chainring with a slightly different offset (usually towards the bigger cogs). Install as per directions first, and then see if you need to do anything further.
    I doubt there's another way to go Eagle for less, unless you get a microshift thumbie, maybe
    https://www.microshift.com/en/produc.../mtb-shifters/
  1. 12 speed XTR and Sram Compatiblity
    By Rmabus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-28-2018, 04:00 PM
  2. Stans 3.30 hub and 11/12 speed compatiblity
    By turquoise in forum Wheels and Tires
    Last Post: 06-20-2017, 09:36 PM
  3. Compatiblity issues
    By pdxmark in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-07-2013, 11:00 AM
  4. Hope Rotor, Shimano 2012 XT compatiblity?
    By Guerdonian in forum Brake Time
    Last Post: 01-27-2012, 12:52 PM
