• 02-03-2013
    J Hartman
    clipless cleat position / Shoe issue / wrong shoe / ?
    I have a set of shimano M540 pedals
    Shimano M540 SPD Pedals at Price Point
    And a pair of shimano M077 shoes
    Shimano SH-M077 Mountain Shoe at Price Point
    While riding my toes on my left foot tingle, and eventually go numb.
    I'm wondering if my shoes are too tight, (the actual velcro, the shoe itself is fine) or the cleat is in the wrong position, or if some shoes just don't work for some people... any input would be great. thanks
  • 02-03-2013
    J.B. Weld
    I'm going to go with shoes a little tight. Many advocate a snug fit for clipless shoes but I think the opposite and prefer some extra room in the toe box. Feet tend to swell on long rides.
  • 02-03-2013
    Slash5
    Cycling shoe fit is tough - many have too tight a toe box for me. Try loosening the front strap, I find that my first try at setting it is usually too tight - when you are putting weight on it, you need more room.
  • 02-03-2013
    csledd281
    Re: clipless cleat position / Shoe issue / wrong shoe / ?
    I have this exact problem and it really pisses me off. I have loosened all straps where the shoe barely stays on and it still happens. I am going to move my cleat back just a tad and see what happens.
  • 02-03-2013
    Flyin_W
    Originally Posted by J Hartman View Post
    While riding my toes on my left foot tingle, and eventually go numb...I'm wondering if my shoes are too tight... any input would be great. thanks
    While misplaced cleats can cause ankle pain or numbness, my $ is on the shoes being too tight / small.
  • 02-03-2013
    sjhiker
    What shoes do you currently ride with?
    I went for a less "roadie" design like these from Pearl Azumi:
    They fit more like a sneaker, with good support and room in the toe box. Sure they are heavier than the more "roadie" style shoes. I've been wearing them for a few years with my shimano m520s.
  • 02-04-2013
    mfowler95
    While it may be that the shoes are too tight don't be afraid to move the cleats before throwing the shoes out. I had the same issue for quite some time, loosen shoes, thinner socks, tighten shoes, etc. with no help. One day I just decided to move the cleats all the way back and have not had an issue since.
  • 02-04-2013
    zebrahum
    It might be that your shoes are too tight, but don't discount having the proper foot support in the shoe. I find that many issues can be resolved by having an orthotic as it tends to distribute the pressure in your foot across more of the shoe by allowing more of your foot in contact with the sole of the shoe. Sometimes, the sole of the shoe also flexes which can cause numbness in your foot as nerves are pinched off.
  • 02-04-2013
    wmac
    Do you point your toes downward while pedaling?
  • 02-04-2013
    drz400sm
    How long has the problem been going on? For example, did everything feel fine till you replaced the cleats? Or is this entire set up new to you?
    My first suggestion would be to continue to move the cleats in different positions. It won't happen on one try, you gotta expiriment. One side may be different then the other.
    I have bad knees and had a similar issue with foot pains. I could find a position that worked well for my knee, but hurt my feet. And vice versa. I ended up changing the pedals to something with more float and...problem solved.
    I'm not saying to buy new pedals...just adding another idea to the list. The amount of float is often overlooked and plays a big role in comfort for some riders.
  • 02-05-2013
    goodmojo
    I had a similar issue where my right big toe would go numb. I could tell it was from how much pressure I put on my feet, my seat height and angle of my feet. Over time the issue just went away as my body naturally adjusted to avoid whatever was causing it.
    Right now Im getting pressure on my left ulnar and my left pinky has been getting numb :)
  • 02-06-2013
    J Hartman
    I went riding again today. I tried not to make the shoe as tight. I didn't get any tingling or numbing today on my 9 mile ride. Awesome. Thank you all for the input.
