choosing size- Surly Karate Monkey- Mtbr.com
Results 1 to 6 of 6
    Jan 2009
    I am gunning for a KM. I ride a 17" Redline Monocog 26 right now with a 80mm stem and 685mm bars. I am 5'9" with a 32" inseam. I am stuck between choosing the 16" and 18" KM. according to the Competitive Cyclist calculator, I should be looking for a frame with a 23.2"-23.6" ETT
    16" KM= 22.7" ETT
    18" KM= 23.6" ETT
    assuming my measurements of my body plugged into Competitive are accurate, that puts the 18" frame at the large end of what should fit me. would it be better to err on the side of too big and put a short stem on it, or too big with a long stem? the 31.2" standover has me a little worried too, but I think it will be ok.
    Some Dude
    Reputation: ccs1676's Avatar
    Hmmm 16" seems a little too small for someone 5'9", then again I am just guessing here. A layback seatpost is another option in addition to a longer stem if you decide to go for the 16".
    FWIW, I'm 6'1 and have the 18" with a layback post and it fits me like a glove. Any chance you can find one to throw a leg over?
    Reputation: jaynestown's Avatar
    Oct 2011
    I say the 18. I'm 5'10, but my inseam is a little shorter than yours, and the 18 would definitely fit me better than the 16.
    "That hat makes you look like an idiot."
    Bicyclochondriac.
    Quote Originally Posted by mack_turtle View Post
    16" KM= 22.7" ETT
    18" KM= 23.6" ETT
    I'm 5'-10" with a ~30" inseam. I usually ride 17"-19" bikes (more often 19"). The 18" KM was too big, I rode it for a while and then got a 16". Fits much better. I run a 70mm stem on it. I was really surprised because the top tube of the 18" is right around what I usually ride, but it just felt too long. Had to run a 50mm stem to make it fit right.
    Also, on mine they measure the seat tube to the top tube junction, not to the seat collar, so the standover was really tight on the 18". Mine is an `07, the new ones may measure differently.
    Fat-tired Roadie
    Nov 2007
    OP - what's the ETT on your Redline? You can use it as a reference bike.
  1. Surly Karate Monkey
    By marchone in forum Commuting
    Last Post: 09-16-2011, 10:30 PM
  2. Choosing between SE Stout and Karate Monkey
    By Midle Age Warrior in forum 29er Bikes
    Last Post: 04-15-2011, 01:36 PM
  3. My New Surly Karate Monkey
    By jeffgothro in forum 29er Bikes
    Last Post: 03-24-2011, 09:20 AM
  4. Replies: 4
    Last Post: 07-07-2009, 04:31 PM
  5. Surly Karate Monkey-What Size?
    By vtho in forum Surly
    Last Post: 12-30-2006, 05:57 PM
