Chain size question- Mtbr.com
Results 1 to 7 of 7
    Reputation: MTBKR-328's Avatar
    New question here. Chain size question
    I got a 2011 Giant Trance X3 and my chain is rusted. Don't know why is a cleaned it and dried it off after every ride. My gears look fine but the chain is pretty bad. I want to pick up a new chain but don't know if my bike would accommodate different sizes or if it had to be a specific length. Any insight/recommendations wl be appreciated thanks!
    Reputation: Enigmma's Avatar
    You need a ten speed chain. The lengths are all the same.
    Take old chain off. Measure it against the new chain and cut to proper length.(Will need chain tool)
    The bike shop will cut and fit for free right?
    Did you lube the chain after cleaning and drying it? If not, that's why it rusted.
    Fitting a new chain is a good skill to have, and a chain tool isn't expensive. If you do it yourself, please be sure to join the chain with the included master link, and not by just pressing a pin back in.
    Thanks for the info. I didn't lube my chain right away on a couple of occasions so that is probably why it rusted. Good to know. Thanks again. I will try to do it myself. I will look into getting a chain tool.
    i also unicycle
    most shops will size the chain for you, especially if you buy the chain tool and the chain and ask about how to use it. at least i know i would. i would probably charge you a few bucks, $5-8 to install the new chain and let you watch/run you through how to use the tool.
    mtbr says you should know: i work in a bike shop.
    bikes & beers (on my blog) http://idontrideenough.blogspot.com/
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    The sign in your avatar is from the Fully Loop. If that is the trail you ride regularly (or really, most SoCal trails), I am skeptical of the need to clean your chain after every ride. Wipe it off with a rag if you must, and then lube it by putting a single drop on each roller. Let it sit for a few minutes, and then wipe it off with a rag again (to help prevent dirt from sticking to it) and you'll be good to go for your next ride.
  1. Replies: 14
    Last Post: 05-01-2012, 12:16 AM
  2. Replies: 0
    Last Post: 11-12-2009, 09:03 PM
  3. Chain line And Chain Ring Question (pictures)
    By kylebooth in forum Singlespeed
    Last Post: 08-23-2009, 09:16 AM
  4. Chain Ring size question
    By Kevan in forum Beginner's Corner
    Last Post: 05-13-2009, 04:40 PM
  5. Chain ring vs chain size
    By fastale in forum Singlespeed
    Last Post: 09-12-2008, 09:25 AM
