Brake Upgrade need advice!- Mtbr.com
Results 1 to 15 of 15
    Reputation: sgtcurry's Avatar
    Mar 2011
    Well I am looking to upgrade the disc brakes on my bike and looked around for the price I can get the Avid Juicy 3 or the BB7's for about the same price $110~ for both the front and back online and I wanted to know which one would be a better buy.
    Thanks in advance!
    Reputation: mitzikatzi's Avatar
    I would say get the Juicy 3's but many will say the BB7.
    LOTS of threads on the Pro's and Con's of both.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    Mar 2011
    Hmm, well I have a Motobecane 700HT and I wonder if either would fit at all. But since they are the same price and if they fit then I am up in the air atm. I hear the Juciy 3's have leaking problems and its a little bit harder to maintain but the stopping power is quite good while the BB7's are easy to set up and maintain yet isnt quite as consistent in the stopping power as hydraulics.
    Quote Originally Posted by sgtcurry
    I have had only 1 problem with my Juicy 3 brakes. I had a sticky piston when I first got the bike. A dab of rubber grease on the piston and no further problems. I think bang for buck great brakes.
    Personally I would forget either of the Avids and get a set of Shimano Deore hydros for a couple of reasons:
    - Shimano use mineral oil, Avid use brake fluid, Mineral oil is MUCH easier to handle, find and bleed [Brake fluid will take paint off anything] in fact you can actually use plain old sewing machine oil in them and they work fine
    - Shimano are very very simple to bleed and maintain - seriously DIY, Avid need a specific bleed kit not to mention horrible brake fluid
    - Shimano pads are very readily available
    - Compared to Avid BB7s which are the best of the cable brakes by far, Shimano hydros are install and forget, change the pads [takes 5 mins] when they wear and thats it, rock solid reliability for years, No adjustment ever, BB7s need manual pad adjustment as they wear as well as brake cable adjustment and replacement, manual pad adjustment is not good if you happen to need it on a steep decent!
    - And yes Avid Juicy 3's leak, my mates 6 month old Specialised FSR XC has cruddy looking resevoir caps from leaky fluid already,
    - For an extra $3 compared to Juicy 3's at a major online bike store you can get Shimano M575's - a much much better brake
    Cantankerous Old Fart
    Reputation: XCSKIBUM's Avatar
    Quote Originally Posted by jeffgre_6163
    Hard to find? your local AutoZone carries DOT 3-4 & 5 brake fluid.
    http://www.autozone.com/autozone/acc...ier=33408_0_0_
    http://www.autozone.com/autozone/acc...uestid=1835552
    As far as the difficulty handling, what's the difference? A little care will keep fluid off paint & a quick wipe will remove any before there is any damage.
    A servicable bleed kit can be made W/items available @ any well stocked autoparts or Hdwe store @ a fraction of the cost of a manufacturers kit..
    Really? Are you saying that Avid pads aren't?
    I found 5 pages of Avid brake pads on e-bay.
    http://shop.ebay.com/i.html?_from=R4...All-Categories
    Compared to Avid BB7s which are the best of the cable brakes by far, manual pad adjustment is not good if you happen to need it on a steep decent!
    Another reason to do your wrenching @ home instead of on the trail.
    But, if one does need to service brakes on the trail, mech. discs are a lot easier to work on.
    Your last point is valid, but the others are not.
    Avid BB7s are top of the line in mech. disc brakes. The hydraulic brakes mentioned here are not top of the line but closer to "entry level"..
    If I was limited to a certain price point as the OP seems to be, I would opt for the best quality I could afford & in this case that seems to be the BB7s.
    Those that say "hardtails rule" never rode the miles I ride on the trails I ride.
    ...snip....
    Avids come complete with discs and mounts. Shimano are often sold without discs and sometimes without mounts.
    I think "brake fluid" Dot 4 is easier to find than mineral oil for shimano brakes. You can't just use any old oil in your shimano brakes.
    Brake fluid can be found in many little towns anywhere you ride.
    You can get Juicy 3 for about $70 to $80 at some online shops. I am yet to see M575 with discs for that price.
    Reputation: GotoDengo's Avatar
    Aug 2010
    Quote Originally Posted by XCSKIBUM
    Even then, hydros are still pretty easy to tweak. Unless the housing is punctured, pretty much just loosening the calipers, pull the brake, re-tighten. You're off. As long as you have a multitool I would even argue hdryos are just as easy/easier to futz with trailside.
    Master of Disaster
    Reputation: Clones123's Avatar
    For me it comes down to the levers. If you like the Juicy 3 levers (feel, reach, travel, etc) then fine. If not, you can set up the BB7's with any lever you like and precisely tune the reach and lever travel (engagement point).
    I'm gonna miss me when I'm gone.
    IMBA member #234701
    Quote Originally Posted by GotoDengo
    Maybe so, but from what I have been told by my LBS owner, the BB7s are as good or better than the entry level juice brakes so why go juice if you are not going to spend the extra $$$ to get an imprioved brake?
    I4NI
    Reputation: S_Trek's Avatar
    May 2010
    Own both, but Elixer 5. I would say the BB's are consistent but it's just not a one finger system. Both systems will stop you. Lock up the rear tire or send you OTB's
    There....Are... Four...Lights!
    Jan 2009
    there is no denying the power of hydros, but I prefer the ease of adjustment on my BB7s. I like analog things that are easy to work on.
    Reputation: random7100's Avatar
    Oct 2010
    I can understand some peoples opinion that simpler is better, but hydro MTB brakes are pretty user friendly ive found, easy to bleed and once set up properly are good for ages.
    Have you thought of good used options? Im in UK so not sure what the market is like over there, but i picked up a Hayes 9 Carbon rear and a Hope Mini front for total equiv to about 90 dollars. the Hayes i just bolted on the complete system as bought and is superb, the Hope just needed a bleed and is spot on.
    You can get good value for money used and id recommend both the above too
    UK MTBer
    Quote Originally Posted by random7100
    Maybe I'm not getting my point across.
    If you want to go hyd, spend the extra money & get a good system, there's no question that a quality hyd brake will be superior to any mech brake.
    If you are going to limit expense to the price of the BB7s get the BB7s as any hdr. brake you will get for that price will not be 1st rate while the BB7s ARE a 1st rate mech. brake. (I've been told)
    Oct 2010
    I was just saying dont be put off by thinking anythings more complicated. And re cost / value, thats why i threw it in there about looking used too. anyhow, hope the OP gets something theyre happy with, which is the main thing. +1
    UK MTBer
